Fuel injector “0” ring question
   / Fuel injector “0” ring question #1
treedawg
Dublin, GA
Kubota M6800, Yanmar YM2000
Is there anything special about diesel fuel injector “0” rings?. Can’t seem to locate replacements for Bosch injectors but I’ve got a large assortment of Viton “0” rings and I’m sure I can find one that’s very close. I assume the Viton rings should work if I can find a close enough replacement?????
   / Fuel injector “0” ring question #2
A quick Google search pops up lots of results on Amazon eBay injector shop etc. for Bosch fuel injector o-rings - diesel or otherwise.
What do you have and where have you looked so far?
Those o-rings are critical for compression and fuel air mixture. I would think that guess and check at the sizes would be a last resort
Here’s a pic of the injector but I can’t find anything online that references the numbers on the data plate. Haven’t tried to contact Bosch but that’s my next step assuming they have a consumer help line.
   / Fuel injector “0” ring question #4
No not really. I have four different o-ring kits, the only one that is special are the HVAC green o-rings.
   / Fuel injector “0” ring question #5
Not to be stupid or anything, but where exactly is the o-ring that you want to replace? Is it on the low pressure side / high pressure side? Is it in the injection pump itself?
That part number (Deutz 04271701) is a common Deutz injection pump, $380 or so on eBay at the moment...The shim under it is a big deal as that sets the timing, and may need to be changed if you change the pump.
All the best,
Peter
So I should be good to go as long as they fit..?? I’m going to see if Bosch will help me tomorrow. They have a help line but I’ve got low expectations.
All the best,
Peter
I pulled the injector “the part I circled” when I was bleeding the fuel system after sitting for 3 years without running. There’s an “0” ring sealing the injector in the base. The motor runs like a champ once you get it going but it’s losing prime overnight. I haven’t been able to locate the leak but I’ve replaced the fuel filter, all the hoses, clamps and inline fuel between the lift tank and lift pump.
Forgot to add pic of the part I removed.
2018 BOBCAT T450 SKID STEER (A51242)
2018 BOBCAT T450...
2005 Kobelco 135SR Hydraulic Excavator (A50322)
2005 Kobelco 135SR...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
1985 Chevy C8500 Auger/Derrick Truck (A50323)
1985 Chevy C8500...
2006 MACK CV (GRANITE) BOB TAIL KILL TRUCK (A52472)
2006 MACK CV...
TRAILER AXLE (A51244)
