fuel injection idea
/ fuel injection idea
Yes it will make a diff. on a diesel.. but us have to use more than, a drop..
It actually has to cover the piston & run down around the rings..
I use 10 squirts from MY oil can when doing a "wet" compression test.. seems to work quite well.
In some cases the pistons are "cupped" & u have to put in enough oil to run down to the rings..
Theres nothing wrong w/ adding an electric supply pump to a "gravity fed" system..
AS LONG AS it doesn't exceed 10 psi.. anymore than THAT & u stand the chance of blowing out the front seal in some cases
OR exceeding the pumping plungers mating surfaces & washing down the inside of the pump, which means fuel in the oil..
...as for the PSI rating of the "temp pump" I was quite aware of and have a 4-7PSI puppy that i'm going to test with.
...as for the oil spray, 'wet test' to the cylinder ... I'm surprised to admit I can't find any memory of ever hearing or "learning" of such a logical method. I want to thank the "choir" on this topic for sure.
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
2015 Kubota L4701 (A60462)
2015 Kubota L4701...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
Sterling 9500 (A61307)
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A58214)
2008 MOTIV...
