Fuel hauling trailer
   / Fuel hauling trailer #11
I think that's for diesel. Gasoline is 40 gallons IIRC.
   / Fuel hauling trailer #12
I don't know about the situation where you are located, but in my area there are usually some larger, fully assembled used trailers to be had for the same money as the HF versions. The tires on them may be used, but often they are larger tires, too, instead of the smaller trailer tires that come on these. Also, the used ones will already have a deck of some kind. I'd think a mesh deck would be good since it would never rot like wood.
   / Fuel hauling trailer #13
I saw a lady at the gas station the other day pumping gasoline into a sizable tank( looked bigger than 55 gallons) on a small wheeled trailer pulled behind her SUV. My mind went back to numerous discussions about legalities of fuel transport on TBN.
I too want to do something similar for diesel. Maybe a 55 gal drum on a pallet with a 12V pump, I don't think I want to dedicate a whole trailer to it. Just pick up up with the forks and put it under the tractor shed. 55 gallons will last me a while so it should not be too much of a pain to do this method.
   / Fuel hauling trailer #14
Only because it is hauling fuel, I'd opt for a better built trailer than anything Harbor Freight offers. Just too risky imo.
Good luck with your project!
   / Fuel hauling trailer #15
I have a 50 Gallon tank mounted in a 48x72" single axle trailer that i use to fuel the tractor and other equipment I use on my property. It works well, easy to hook up and run down the street to fill when needed. I just hook the power leads to a jump box when I need to fill something.. Don't have to keep a separate battery charged up that way.
   / Fuel hauling trailer #16
My portable fuel tank;
   / Fuel hauling trailer #17
I’m toying with the idea of getting one of these lightweight trailers to mount a diesel tank (< 50 gallons) and make for a mobile fueling station with a hand crank pump. It would be easy to hook up the trailer and haul to the fueling station, fill it and park it under a carport at home. No lifting heavy jugs or fork lifting and strapping down tanks in the back of the truck. I know the small wheels wouldn’t be great for distance travel, but it should be good for making a ten mile run to the fuel station and back home. Thoughts?
https://www.harborfreight.com/1090-lb-capacity-40-12-in-x-48-in-utility-trailer-62665.html
This is going to be one of those "do as I say, not as I do" posts!
That being said, IBC containers are NOT an approved method of storing, dispensing or otherwise dealing with fuels of any kind - specifically, Gas or Diesel!
Phew, now that that's out of the way 🤣, I use both the 275 & 330 gal IBC Totes for my fuel farm and transfer tanks. 275's for Unleaded and "On-Road" diesel and a 330gal for "Red (off-road) diesel. I have 12V pumps attached to the lid and use a 2" stainless chase nipple and 2" stainless coupler with a vent cap placed in a convenient place for refueling on top of the diesel totes - on the Unleaded tote I used sch80 Street 45 and a coupler (inside the tank) so the vent cap (refuel) was at a 45. I've been using this system, under cover so sun doesn't degrade plastic, for almost 10 years without any issues. Is it safe? Probably not! Is it a cheaper alternative to 200+ gal transfer tanks that will fit in a pickup bed? Absolutely. Are they easily moved from the ground to the pickup bed? Yup!
I AM NOT advocating the use of this system, your milage may vary.
That would certainly be a cheaper way to go. But my interest in the fuel trailer is to stop having to load/strap down and unload a container from the truck. With a trailer I can hook it up, drive to the station and fill, then drive it into my barn and detach. Whatever kind of tank I get, I want it on wheels.
   / Fuel hauling trailer #19
I made one for the farm from a shortbox S10 pickup, made the hitch and frame long enough for a crossbox/toolbox in front of the pickup box for the nozzles, battery and grease gun.
2 sixty gallon tanks, cabled to the frame, with 12v pumps and filters.
15" trailer tires, handles very well.
Gets offers to sell it at the fuel station. (y)
Small pickup box trailers are plentiful, decent size tires and lights.
   / Fuel hauling trailer #20
That makes sense, just mount one on a trailer - unless you don't need that volume. The other nice thing I like about the totes is that you know how much fuel is left. First fill up put a sharpie mark with #gals. Simple calculation to determine where 3/4, 1/2, 1/4 (or gal amount) point is and mark on tank.
POWER LINE 180 LOT IDENTIFIER 82 (A53084)
POWER LINE 180 LOT...
2018 Infiniti QX60 SUV (A51694)
2018 Infiniti QX60...
Toro Workman 175 Sprayer Cart (A50324)
Toro Workman 175...
2019 JOHN DEERE 5090M LOT IDENTIFIER 84 (A53084)
2019 JOHN DEERE...
UNUSED CHERY INDUSTRIAL 9.5' WORKBENCH (A51248)
UNUSED CHERY...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51247)
KNOW BEFORE YOU...
