Oil & Fuel Fuel gelling?
/ Fuel gelling? #1
Barnboy
Decatur IL
Kubota B3030
We had our first snow in central Illinos so I had my first chance to try out the B3030. The first day I plowed my drive in less than 15 min.The next day I wanted to play some more so I went to the neighbors house 1/4 mile away. First neighbor went fine. Started on the second neighbor and I could barely get in his drive. At first I thought I was losing traction. I finally made it to his garage and lowered the blade. I started to pull foward and the tractor acted like it was losing power.The engine didnt sound like it was under a load. Not knowing what was hapenning I rushed home to check the sudt level. It was fine. The only thing I could think of was the fuel was purchased in the summer. Was the fuel gelling causing low power. If it was gelling did I ruin anything?I went to walmart and purchased some additive and tried moving snow today. Everything seems to be fine but I wasnt out as long.
/ Fuel gelling? #2
You didn't mention the temperature. Down to about 15F, summer fuel should work OK. Fuel gelling WILL cause low power, in fact it will ultimately result in zero power output.
You didn't hurt anything.
/ Fuel gelling?
It was around 15 deg. It was just odd the motor sounded fine. I put pressure on the hydro petal and it didnt feel like it was getting power to the wheels.Glad to hear I didnt hurt anything.
/ Fuel gelling? #4
i was reading on another post about loss of power right around this time of year. they said to change the fuel filter every fall because water in the filter will cause problems. it helped that persons particular power loss problem.
/ Fuel gelling?
At 50 hrs I replaced all filters and changed hydro fluid to sudt. I currently have 65 hrs on it. But thanks for the reply. Two heads are beter than one. /forums/images/graemlins/smile.gif
/ Fuel gelling? #6
Anytime the temps drop to less than 30F, I dump fuel conditioner in both the tractor and the truck. Cheap insurance. I also keep a bottle of "MeltDown" around in case the fuel should still happen to gel up. Meltdown can be bought at any truckstop like T/A or Pilot. /forums/images/graemlins/grin.gif
/ Fuel gelling? #7
I think you will get pretty good consensus on this board that the Power Service Diesel Fuel Additive is highly recommended in the winter time. It can be found at Walmart and NAPA. Get the white bottle. It has all the additives to keep you running in the winter (and probably the summer too). In a bind you can probably through some kerosene in the tank too that might thin out the #2 enough to get you going but that would not be something to do on a regular basis.
/ Fuel gelling? #8
I came into the same problem with losing power/smoking with my B7510HSD but my outside temp was around 35 deg. I work at a Chevy dealership and asked some of our diesel techs what I should do. They said it was more than likely water in the fuel. I had 2 choices, one, flush the fuel system, two, use a additive called Howes Diesel Treat. It cleared everything up in two seconds! Made a believer out of me. I will run it in everything I own now. Well worth it.
/ Fuel gelling? #9
I have a little story that may shock some of you. Years ago I was a tech at a Chevy dealer. While there, I went to a class at the Warren Technical Center, near Detroit, on the then new 6.2L Diesel engine. We discussed fuel gelling at cold temperatures and were told by the instructor that it was perfectly safe, acceptable and recommended to add gasoline to the diesel at a 1 to 10 ratio. In fact, he said that it would not hurt anything to go as high as 1 to 4 on the mix in extremely cold weather. I had never heard of this before so I was skeptical. The instructor assured me that it was OK and that there was enough lubrication in the diesel fuel so that no harm would be done to the injection pump and the gasoline would not damage the engine itself. Since he was a genuine GM instructor at the GM factory school I decided he must know what he is talking about. During the following winter I had the opportunity to try it myself. My service manager asked me to take a customer's new Chevy K2500 w/6.2L pickup home for the weekend to try and diagnose an odd driveline vibration. That Sunday morning it was 22 below zero which is extremely cold for southern Michigan. I needed to make a trip to the store so I took the truck. I had plugged the block heater in over night for just such an occasion as I knew it was going to get cold. The truck started right up. I let it warm up for a few minutes so I would have some heat and took off. The store was about 3 miles away. The first two miles were fine and then it started to lose power. I thought it may be fuel gelling so I switched to the other one of the dual tanks. It recovered and ran OK until I was almost to the retail part of town. As it started to die again I remembered what I had learned the summer before about adding gas to the diesel fuel. I quickly spotted a gas station and almost made it, stopping about 20 feet short of the pumps. No problem, I thought, I'll just go in and borrow a can, put some gas in it and then pour it into the truck. Wrong. The station did not have a can to lend so there I was, 20 feet away from salvation. There was a K Mart about a block away so I walked over to it in the -22 degree weather with the wind blowing and bought a 1 gallon can. I went back to the station, bought 1 gallon of gas and poured it into the tank that was about half full. I then pushed on the side of the truck to get it rocking so the gas would mix with the diesel and hopefully melt the wax (so called gelling is actually the parafin wax that is in all oil. At cold enough temperatures it turns into little globs of clear wax that plugs things up and stops the flow of fuel) that had collected on the filter sock on the pickup tube in the tank. It worked. The truck started and I was able to drive back home with no more problems. (Later versions of the 6.2L engine had fuel line heaters near the engine and no filter socks in the tank.) It made a believer out of me. In the 23 years since and having driven diesels most of those years year around in Michigan I have never had a fuel gelling problem. I think the additives that are available today for diesel fuel are a much better solution for fuel gelling but in a pinch, I would not hesitate to use gasoline again. It kept me from a long cold walk home.
/ Fuel gelling? #10
I have owned 4 diesel trucks over the years, Anti gel is cheap insurance, I added it to every tank full when the weather was cold.
KC
/ Fuel gelling? #11
Had a 68 MB diesel and the owners manual said same thing ...in a pinch, cut with "engine kerosene" or gasoline ...but, only a small percentage ...remember those glow plugs!! Did it many times, myself in NH
/ Fuel gelling? #12
Just some more info on fuel gelling. This year I switched to low sulphur #2 B20 fuel oil to heat my home, I also siphon some out to use it in my Kubota. They said it's treated to not gel to -20F and they have been delivering treated LS #2 B20 for a couple years now without any problems in the winter. Although during January/February deliveries they do add some Kerosene to the mix for people with outside tanks. I'm using the same stuff in my Kubota without any problems so far. I also live in Southern MI around Ann Arbor area.
/ Fuel gelling? #13
<font color="blue"> told by the instructor that it was perfectly safe, acceptable and recommended to add gasoline to the diesel at a 1 to 10 ratio. In fact, he said that it would not hurt anything to go as high as 1 to 4 on the mix in extremely cold weather. </font>
Thanks for sharing that, it is no wonder the poor reputation these GM diesel engines and their Stanadyne injection systems have with that kind of information being voiced by their technical services.... /forums/images/graemlins/shocked.gif
/ Fuel gelling? #14
I was waiting for someone to make a comment about the 6.2L. Definately not one of GM's better moments. They did have their share of problems but, I doubt if any of them were caused by running a little gasoline in the diesel fuel from time to time. As JOEL* said, even Mercedes-Benz said it was OK use gas to prevent gelling in a pinch. Funny thing about those Stanadyne pumps, too. They had been around for years before GM used them and they worked fine. In fact my dad's 1967 3020 JD with over 8000 hrs has a Stanadyne pump and it has never needed any work. I guess it was the jump from a tractor to an automotive application and the related exhaust emission restrictions that caused a lot of the problems.
/ Fuel gelling? #15
I believe that there are 3 issues w. respect to cutting w. gasoline: (a) the volatility and your glowplugs; (b) the higher the octane, the less "knock", which translates into poor "compression ignition, which is the way your diesel fires; and, the lower specific energy in a gallon, which means less power/less mileage. All this argues for using a small percentage, and using the lowest octane (regular) gas.
My experience w. diesels is limited to two MB's, a Chevy burb w. 6.2L, an isuzu I-mark, and my F-350 superduty 6.0L ...besides my Kubota
2017 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2017 Peterbilt 320...
KMC 14' FIELD CULTIVATOR (A64278)
KMC 14' FIELD...
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
2017 Ford Explorer SUV (A64557)
2017 Ford Explorer...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
