Fuel gauge Problem
/ Fuel gauge Problem #1
Anonymous Poster
Epic Contributor
This weekend my fuel gauge quit working on my NH1725.
When I first start the tractor it gives a reading, I think is accurate but then it drops to empty after running for a few minutes. Does this sound like the sending unit or the gauge and how hard is it to replace?
Mark
/ Fuel gauge Problem #2
You want a wild guess? How about a loose wire somewhere, or a wire that's so close to a heat source that it's going to melt the insulation, if it hasn't already.
Bird
/ Fuel gauge Problem #3
I just bought a new TN65 and after a couple of weeks the fuel guage stopped working. I grounded the guage with the key on and determined it was working fine. Pulled the unit out of the fuel tank and found the float was water logged with diesel fuel, had a slight crack(had to have been a mfg defect. Took some fuel proof glue and filled the crack and now everything works fine.
/ Fuel gauge Problem #4
NAPA parts stores have a universal fuel guage and sending unit in a kit, cheap..the guage is the same size as most aftermarket ammeters, oil pressure etc etc guages, round, 2 inches i think.
heehaw
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
