Fuel Gauge on M7030
   / Fuel Gauge on M7030 #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
My fuel gauge works part of the time. Right now it is stuck on 1/2 tank. How much of a job to replace or repair? Or do I stick with the stick?
   / Fuel Gauge on M7030 #2
That depends on if the problem is with the fuel gauge in the in the instrument panel or the sending unit in the tank. The sending unit in the tank should be relatively easy to repair, the gauge not so easy and likely more expensive. You could remove the sending unit and test it with a multi meter. Or just continue using the stick method and know for sure where your level is at.
Hope this helps.
20ft Bi-Parting Gate (A51573)
20ft Bi-Parting...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
(30) Galvanized Steel Public Space Fence (A51573)
(30) Galvanized...
