Fuel Gauge on M7030
   / Fuel Gauge on M7030 #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
My fuel gauge works part of the time. Right now it is stuck on 1/2 tank. How much of a job to replace or repair? Or do I stick with the stick?
   / Fuel Gauge on M7030 #2
That depends on if the problem is with the fuel gauge in the in the instrument panel or the sending unit in the tank. The sending unit in the tank should be relatively easy to repair, the gauge not so easy and likely more expensive. You could remove the sending unit and test it with a multi meter. Or just continue using the stick method and know for sure where your level is at.
Hope this helps.
KC Skid Steer 72in. Fine Skeleton Bucket High Side (A49339)
KC Skid Steer...
1901 LOG TRAILER (A45678)
1901 LOG TRAILER...
2015 KENWORTH T800(INOPERABLE) (A48992)
2015 KENWORTH...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A45678)
2016 VOLVO VNL...
Holland Transplanter (A49251)
Holland...
Hiniker 15’ Stalk Chopper (A47369)
Hiniker 15’ Stalk...
