fuel gauge fuses
/ fuel gauge fuses #1
Richard R.
Molino FL
2000 ford/ bushhog loader, 3203 john deere, 5035 mahindra ML130 FEL
I have a 3203 and the fuel gauge has stoped working. the manuel does not denote a fuese for the fuel gauge.
any input. thanks
/ fuel gauge fuses #2
Might pull the fuel sender unit out of the tank and test it, or try to get some readings from it while in the tank. The unit must read the resistance depending on the float position. Might be the float is stuck?
Do you have the tech manual, or are you referring to the operators manual?
