dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,786
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Yes, the drain is off the very bottom of the bowl and it leaks with the screw tightly in place and I can also blow through it with the screw in place just as if the screw was removed.
On my Honda ATVs, the drain screw depends on a tight seal between
the beveled tip of the brass screw and the seat. There is no O-ring. The
problem I had is that water would get to the bottom of the float bowl
and corrode the end of the screw, which kept it from tightly sealing. You
might try epoxy on the threads of the screw. If you ever need to remove
the screw after that, heat it first.
