Fuel Filtter B2650
   / Fuel Filtter B2650 #1
coupman35
Northen Ontario
Now a L4060 had B2650
Small question is there a fuel shute off valve before the filter so you can turn off fuel when changing filter . Or do you have to train the tank.
   / Fuel Filtter B2650 #3
It shuts off on its own.
You will lose a little fuel, but not much.
   / Fuel Filtter B2650 #5
Manual says to not have fuel tank more than half full when removing fuel filter element to avoid excess leakage . Then to fill fuel tank after filter replaced and start and run engine for 30 seconds, then shut engine off, to bleed air from system.
   / Fuel Filtter B2650 #6
IIRC........I've changed the fuel filter with a full tank, as well as a 1/2 tank and it didn't seem to make a difference.... i.e. not much leakage either way.
   / Fuel Filtter B2650 #7
Cool! I'm going to do my 200 hour service today, and it will be the first time I changed out the fuel filter. my tank is already at half so I'm not going to worry about it anyway.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52748)
2017 Yale GLC050VX...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
16ft T/A Flatbed Equipment Trailer (A50323)
16ft T/A Flatbed...
2013 Ford F-250 Animal Control Truck (A50323)
2013 Ford F-250...
2005 Blue Bird BB Conventional Bus, VIN # 1BAKBCKA45F219634 (A51572)
2005 Blue Bird BB...
LandPride PFL1242 Pallet Forks (A50120)
LandPride PFL1242...
