Oil & Fuel Fuel Filter valve assy.
   / Fuel Filter valve assy. #1
Buckman1
Leesville, Louisiana
ISEKI TS2205
I recently purchased a Iseki TS 2205. I couldn't find the model number on it before I bought it wanting to learn as much as possible about this tractor. I would like to replace the Fuel Filter valve assy, and other filter that need to be replaced becaused it was poorly maintained.
I am enclosing an attachment with post hoping someone will know where I can purchase this filter assembly,
  • Fuel filter TS series.pdf
   / Fuel Filter valve assy. #3
Just wondering, even if poorly maintained you should not have to replace the whole assembly unless its broken, what is wrong with the assembly you have?
Yes I will have to replace the whole assembly. The previous owner replaced the original filter assembly with something that came from ?? and it is leaking.
   / Fuel Filter valve assy. #5
You may want to do a search for the compact series of the Massy ferguston tractors as they use to be made by Iseki. If you find the size that yours is try and get a parts breakdown and see if it looks the same. The part number will be different than yours so you cannot go to a dealer and ask as they won't look it up for you unleess they have the size tractor in their brand
   / Fuel Filter valve assy. #6
I just did a quick search and go to AGCO parts put in your tractor model and name. This is where you will have to get your parts from. I think the only way you will be able to order them is thru an AGCO dealer. I don't know if the part you need is still available
Thanks I found a parts supplier that has the part I need.
   / Fuel Filter valve assy. #8
I need the same item. Who is your parts supplier?
1999 KENWORTH W900 TANDEM AXLE SLEEPER (A52141)
1999 KENWORTH W900...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
2020 KUBOTA RTV...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52748)
Texas Post Driver...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
