Oil & Fuel Fuel filter on CK20 and adding lubricant to the road diesel.
   / Fuel filter on CK20 and adding lubricant to the road diesel. #41
Every time I have gone to the dealer to get a fuel filter for my DK45S they always try to give me the cartridge filter, and not the spin on. supposedly the DK45 takes the cartridge, and the DK45S takes the spin on.
So had some time today to look at little deeper into the filter issue I have had, and here are the pictures.
Looking at the bottom of the filter housing after I removed the bolts holding it on. See anything that should not be there.
This is what I removed from the filter housing. Seems the previous owner failed to remove a filter top sometime in the past.
New filter (Baldwin PF-872) and o-ring fit without issue. Used the Baldwin because it has a metal bar running top to bottom so crushing should not be an issue.
Rancho
   / Fuel filter on CK20 and adding lubricant to the road diesel. #43
Rancho
Question what was the cost savings using the bladwin filter verses the Kioti dealer filter?Just curious?
   / Fuel filter on CK20 and adding lubricant to the road diesel. #44
+1 on the aversion to OEM filter?!
I suspect the answer was stated as the bar prevents crushing, but so does having removed the piece that was left behind in the housing previously, so essentially no need for anything beyond OEM. I'd be curious if the filter top that was found in the housing was from an OEM filter?
   / Fuel filter on CK20 and adding lubricant to the road diesel. #45
Rancho
Glad you got it sorted out and found the problem. :thumbsup:
Averting Stealerships, always a good thing.
   / Fuel filter on CK20 and adding lubricant to the road diesel. #46
When tractor dealers are out of business where are you going to buy your tractor?Walmart?What if your tractor needed major repair that you were not capable of doing?I always support my local dealer because he knows what I am talking about when I need parts and service and will not give me that blank stare that you get at the big box store when you ask questions.
I am not opposed to dealers and buying parts from dealers, but the closest dealer I know of is over an hour away, if there had been one here where I live I would have been down there asking about why the filter would not go on correctly and they might have said hey maybe you have an old filter cap stuck on the inlet. But there is not a Kioti dealer here, so I do the best I can.
FleetPride sold me the PF872 for 5.15 including FL sales tax.
BTW, do you buy your oil filters, air filters etc... from the dealer you bought your car/truck from?
Rancho
   / Fuel filter on CK20 and adding lubricant to the road diesel. #48
Rancho
Good for you,glad you found a filter that finally fit.
   / Fuel filter on CK20 and adding lubricant to the road diesel. #49
See below answer.
Rancho
Some other guy before you didn't buy a fuel filter from the dealership and they had to close, according to coobie. :thumbsup:
   / Fuel filter on CK20 and adding lubricant to the road diesel. #50
See below answer.
Typical walmart answer.LOL.
2026 Anvil Trailer (A56859)
2026 Anvil Trailer...
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A58017)
2014 INTERNATIONAL...
2011 Atlas Copco XAS 375JD6 Towable Air Compressor (A55973)
2011 Atlas Copco...
Stanley hydraulic power pack (A56435)
Stanley hydraulic...
HAND SAWS (A58374)
HAND SAWS (A58374)
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
