Fuel Filter - bad fuel
/ Fuel Filter - bad fuel #1
RandyinTN
Monterey Tennessee
NX4510H with backhoe and FEL
I'm not sure what happened to my fuel. Tractor is a NX4510, always stored under a carport. But the diesel fuel cans were not. For awhile the "water in fuel" light would come on every 1.5 hour of operation. I would drain the fuel filter and all would be well until another 1.5 hour went by.
Next I started to use a fuel filter when adding diesel to the tractor. Am guessing this helped because now the light doesn't come back on for 3 hours.
Plenty of sediment in the bad part of the fuel after I drain the filter (drain it into a clear plastic jar).
Tractor now has 66.8 hours on it.
Keep on doing what I'm doing and change filter at 100 hours?
Or change filter now?
/ Fuel Filter - bad fuel #2
Change the filter. You may need two or three. Also add some fuel dryer to your tractor tank.
/ Fuel Filter - bad fuel #3
You need to figure out where the bad fuel is coming from. Is your fuel tank on the tractor rusty or is water getting in somehow?
No rust, tank is plastic. As I mentioned before tractor is stored underneath the carport 100% of the time.
My best guess is water seeped in the fuel jugs when they were stored behind the workshop exposed to the elements. This is why I began to filter the fuel going to the tank.
If I pre fill the filter before screwing it in place will the system need to be bleed?
/ Fuel Filter - bad fuel #5
With large amounts of sediment in the water separator / filter there is more than just a water in the fuel problem. Either your cans were contaminated in use, or the source fuel is contaminated. The water could be from the source, or while stored outside.
I recommend Mr Funnel filters for dealing with contaminated fuel. Is the filter you're using a water blocking type?
Consider draining the tank and running it back in with the water blocking Funnel filter, change and/or clean filters and separator. I personally do not pre fill fuel filters, so the system needs to be bled. I suspect even with pre filling the fuel system would require bleeding, but every tractor is different. It's no big deal to bleed modern tractors.
/ Fuel Filter - bad fuel #6
Sounds to me like you need a Racor fuel polishing filter between the fuel tank and your primary filter. Since I installed them on my Kubota's, I've not changed a primary filter or had anything in the sediment bowl and with a Racor (or a clone), the lower bowl is clear and drainable, so you see what you have immediately.
The fuel filter I am using now when adding diesel to the tank is a Mr Funnel AF8CB, which also filters water.
I been keeping track of the hour meter in between notices to drain the water and the frequency has slowly been increasing since starting to pre filter the fuel going into the tank. So at least I am headed in the right direction.
I'll order a new filter and change it out and go from there.
Will change it out every 25 hours until the issue is resolved.
/ Fuel Filter - bad fuel #8
A lot of modern tractors are self bleeding. I mine it bleeds its self by just turning the tractor on and off a couple times without starting it.
2017 FREIGHTLINER CASCADIA 6X2 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2012 International DuraStar 4300 Digger (A62613)
2012 International...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Kubota M125X (A60462)
2354 (A64281)
2354 (A64281)
12-16.5NHS Skid Steer Wheels and Tires (A61572)
12-16.5NHS Skid...
