Fuel economy on 318
   / Fuel economy on 318 #1
yellowsocks93
MN
John Deere 990 MFWD and a few others
How long can you guys go before filling the tank? I cut for a couple hours and was down half a tank.
   / Fuel economy on 318 #2
I haven't really paid close attention but it does seem to like it's fuel (I bought my 318 this past spring).
   / Fuel economy on 318 #3
Never had a 318, but I did have a Case/Ingersoll 448 with the 18hp Onan engine. I can't remember the size of the tank, but I know two hours of mowing would put quite a dent in the gas tank!!
Will
   / Fuel economy on 318 #4
Nick,
That sounds about right for fuel usage. I know my 318 will not win any economy contests. Don't forget it is a twin cylinder, you will not get the economy of a K series Kohler. Still a great tractor in my opinion.
Ken /forums/images/graemlins/smile.gif
   / Fuel economy on 318 #5
Nick - a 318 is thirsty. I think mine was running rich on top of things - but by the time I cut the whole 'yard' (around 2 acres and change and around 1 1/2 hours due to the manuvering required) - I'd go through a big chunk of that 4 1/2 gallon tank.
Sounds like your numbers are fine (for a 318). Like Ken said, got to remember that's nearly an 800cc twin - not your typical GT one-lunger.
Have fun!
   / Fuel economy on 318 #6
IF YOU THINK AN ONAN IS THIRSTY, TRY A 20 HP BRIGGS. MY NEPHEW JUST GOT AN L120. HE THOUGHT THERE WAS A HOLE IN THE GAS TANK!!! MY 16HP KOHLER GOES A LONG TIME!
   / Fuel economy on 318 #7
Of course all this underscores why the 'ultimate' 318 is a 332! (a 318 with a nice compact Yanmar diesel under the hood).
Unfortunately, around here - 332 owners know what they've got! /forums/images/graemlins/wink.gif
   / Fuel economy on 318 #8
I have an AC 620 with a 19.5 HP Onan engine. The fuel tank is 3.8 gallons. Two hours and I have to refuel. I ran my 35 HP Kubota diesel today for 8 hours and used less than 8 gallons of fuel.
OrangeGuy
I mowed with one all last year and loved it. It did have a tendency to overheat after an hour or so though. The radiator was hard to clean you had to use a garden hose each time and the grass go trapped between the firewall and radiator.
Thanks guys for your replies! I should be tearing the motor apart next week or so since she's running a little rough and smokes so bad it looks like a diesel when it runs. After a few hours of mowing I was down into the add one pint mark on the dipstick. Started full. I'm going to try and do it myself and if I get stuck I will take the motor into work.
2000 Ditch Witch 3700DD Ride-On Trencher (A53421)
2000 Ditch Witch...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
