Oil & Fuel Fuel Capacity
/ Fuel Capacity #1
StoneHeartFarm
Michigan
Kubota L3650/AC B210
I filled the tank on my L3650 this weekend and starting with 1/4 tank, I was surprised to need only about 5 gallons to do the job.
Does anybody know what the tank capacity is on this unit? I guess I expected something like 12 or 14 gallons and it appears more like 7.
Steve
/ Fuel Capacity #2
tractorsmart.com has all the specifications for your tractor. Unfortunately when I went to it, the L series page was down. I checked the M series and B series and they have a great list of specifics for each tractor including engine type and associated data.
/ Fuel Capacity
Rat,
I already checked it and printed it off. Unfortunately, they don't list capacities other than engine displacement, bore, stroke, etc. Nothing on the tractor itself, just the engine.
Just seems like a 7 gallon tank is a little small for a 4 cyl tractor. About 1/2 that in my car. /forums/images/graemlins/shocked.gif
Steve
/ Fuel Capacity #4
I have an L3600 and the capacity is 9.2 gallons. I'm betting yours is the same. If you're going by the fuel gauge then you have the same problem that I do. It lies to you. When mine is on E it really has a couple of gallons left. I usually fill it before then anyway but when mine would get down to a quarter tank it would only take five gallons as well.
/ Fuel Capacity #5
They have another section that is not in the technical section that has even more info. I believe it is linked at the bottom of the front page.
Here is an example for the B2910HSD
Specifications for the Kubota B2910HSD (4WD) Tractor
Engine
Model V1505-E-D16
Type Indirect Injection Vertical, water cooled, 4 cycle diesel
Number of cylinders 4
Total displacement (cu-in.) 81.5
Bore and stroke (in.) 3.1 X 3.1
Gross engine horsepower 30.0
Power takeoff horsepower 22.0
Maximum torque (ft. lbs.) 66.0
Capacities
Fuel tank (U.S. gallons) 6.9
Engine crankcase (with filter, qts.) 4.3
Engine coolant (qts.) 4.7
Transmission (gallons) 3.83
Dimensions
Overall Length (without 3 point hitch, inches) 99.2
Overall Width (at minimum tread setting, inches) 53.8
Overall Height (with ROPS, inches) 78.5
Wheel Base (inches) 65.6
Minimum ground clearance (inches) 14.6
Weight (with ROPS, lbs.) 1763
Drive Train
Front tire size (standard) 7-12
Rear tire size (standard) 12.4-16
Clutch Dry, single stage
Steering Integral power steering
Transmission Hydrostatic transmission with 3 ranges
Control type Single "rocker" pedal for forward-reverse
Brakes Wet disc type
Minimum turning radius with brakes (ft.) 6.9
Hydraulic System
Hydraulic control type Position control type lift
Pump capacity (gallons per minute) 6.4
Three Point Hitch Category 1
Maximum lift capacity at lift points (lbs.) 1655
Maximum lift capacity at 24" behind lift point (lbs.) 1300
Power Take Off
Rear PTO type SAE 1 3/8", 6 spline with overrunning clutch
Rear PTO speed 540 RPM @ 2600 engine RPM
Mid PTO type USA #5, 10 spline involute
Mid PTO speed 2500 RPM @ 2578 engine RPM
They have many listed but unfortunately they must have the L series down to update it.
/ Fuel Capacity
Rat,
I've missed that section entirely. I'll have to keep my eyes peeled for it.
Steve
/ Fuel Capacity #7
StoneHartFarm
The fuel tank capacity of an L3650 is 7.7 gallons. Hope this helps.
Lewis
/ Fuel Capacity
</font><font color="blue" class="small">( StoneHartFarm
Lewis )</font>
Thanks, I guess I was just amazed that the tank filled so quickly, and thought maybe the guage was off by 8 gallons or so. I was plannng to grab an extra fuel can. Now I guess I can get by with just the one. /forums/images/graemlins/cool.gif
Steve
/ Fuel Capacity #9
That's interesting. The capacity of my 3050 is 11.4 gallons. I have noticed that with the accumulation of hours, the engine seems to use less fuel. I am glad the tank is not bigger, the fuel might get STALE!!!!
/ Fuel Capacity
Mine doesn't appear to use much either, about 1/4 tank in 3 hours of light FEL work. (Course, that depends on the size of the tank.)
Steve
/ Fuel Capacity #11
Daryl, when did you get another tractor. I was checking out the 3050, but came up empty handed. I'll bet its just like the 5030. /forums/images/graemlins/wink.gif
/ Fuel Capacity #12
Rat,
I'm not Daryl...but if I remember right...wasn't 5030 3050 when he first joined us here?
No doubt in my mind that when he starts thinking 'bout his 'bota he gets all excited and his fingers get confused... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Fuel Capacity #13
RaT:
When you get old, your finger get stiff and that's about all /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif /forums/images/graemlins/smirk.gif
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2023 CRUISER RV SHADOW CRUISER (A67714)
2023 CRUISER RV...
TANK MANIFOLD (A67714)
1999 TRAILMASTER PUP TRAILER (A67714)
1999 TRAILMASTER...
Whisperwatt 125KW DCA-125USJ Gen Set (A64911)
Whisperwatt 125KW...
2015 Case TR320 (A64911)
2015 Case TR320...
