Fuel cap off for 2 weeks and tractor in the field???
   / Fuel cap off for 2 weeks and tractor in the field??? #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Pulled a bone head mistake and left the fuel cap off my 7710 after fueling up. Went on vacation with tractor parked under tree. Maybe rained 1/4 inch entire time. Came back and realized what I had done. Dealership said to drain all fuel, replace with about 5 gallons of clean fresh fuel, run for about an hour, stop and replace fuel filter and clean sediment bowl, fill up with clean fuel, pour in fuel additive and not look back. Any other advice??
   / Fuel cap off for 2 weeks and tractor in the field??? #2
don't forget to put the cap on when done :D
   / Fuel cap off for 2 weeks and tractor in the field??? #3
If the valve to sediment bowl/filter assembly was left closed then I would not worry about downstream stuff. I'd valve the tank off, take the hose off and empty the fuel in ot an appropriate jug. Before I do anything I'd park the tractor in the sun so after draining the tank heat up without the fuel cap. I might cover the hole up with a can partially to keep the potential rain out but allow the water vapor to scape. It does not harm to change the fuel filter and sediment bowl as well, it might be a good opportunity now.
JC,
   / Fuel cap off for 2 weeks and tractor in the field??? #4
You may get some water in the injection system doing this.:)
   / Fuel cap off for 2 weeks and tractor in the field??? #5
I suggested to put an empty can over the opening. Can also wrap it loosely on top with plastic to shed rain water, if indeed there is rain but to allow for evaporation and escaping of water moisture.
JC,
   / Fuel cap off for 2 weeks and tractor in the field??? #6
I was kinda thinking about what happens when you move the tractor.:)
   / Fuel cap off for 2 weeks and tractor in the field??? #7
I'd drain the fuel before starting the engine. Agree with Egon that keeping any moisture out of the system beyond the tank would be top priority.
Sounds like the dealer has the best plan. Drain, put 5 gal fresh in, run, drain, change filter and put in more fresh fuel.
I'd guess the water was on the bottom and right in position to go to the fuel filter and then maybe the engine.
   / Fuel cap off for 2 weeks and tractor in the field??? #8
If you indeed only had 1/4" of rain, then the amount of water in that tank is less than a quarter cup. There's a good chance it's less. That amount should be caught by the filter bowl. I think your dealer gave you great advice. Drain the fuel, add fresh, change the fuel filter and go for it.
GOT ER DONE. Thee hours later and covered in diesel but I got her done. Got 8 five gallon buckets full of diesel. My separater was very dirty, but I suspect it haddnt been cleaned for some time so maybe some of this needed to be done anyway. Now have a fresh full tank of fuel with a can of additive, new fuel filter, and a clean separater. I can sleep good tonight. Thanks for the advice, suggestions.
   / Fuel cap off for 2 weeks and tractor in the field??? #10
Sounds like it would have made a good video. :D
Glad to hear of the progress. 40 gallon....Wow. Think maybe I'd a just.....nah! You did the right thing. IMO :)
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A52128)
NEW 2022 Load...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
2013 Ford F-150 XLT - EcoBoost, Blown Engine, Good Parts Truck (A51039)
2013 Ford F-150...
Land Honor Quick Attach Vibratory Plate Compactor (A50514)
Land Honor Quick...
Case 580D (A47384)
Case 580D (A47384)
2014 Ford Explorer AWD SUV (A50324)
2014 Ford Explorer...
