Fuel bleeding issue.
   / Fuel bleeding issue. #1
Spikes
Bronze Member
Rogers, Ar.
Kubota L3450
Hi all,
I changed the fuel filter on my L3450 4 cylinder a couple of days ago and today I used the tractor for about 45 minutes with zero issues. I turned it off to grab a glass of iced tea and when I came back 10 minutes later it would start for a few seconds and shut off.
The issue 'felt' like air intrusion so I bled the lines at the injectors. I did get some air at each of the back three.
The number 1 injector line isn't getting any fuel at all to speak of. I can completely take the line off while the engine is running and nothing comes out but maybe a drip or two.
I took a video of the issue HERE. (Sorry for bad quality, it's just an iPhone video)
I have heard people talk about a bleeder screw on the injection pump but I can't find one and the owners manual doesn't show anything about one.
Thanks.
I should add that the other three lines squirt fuel strongly when I crack them open. The front one does nothing.
Well, despite all the help, I just came home after letting the tractor sit overnight, cracked the #1 line and started the tractor and it bled right out.
I guess it just wanted to sit for a while.
   / Fuel bleeding issue. #4
Glad to hear you got it going, with all the help and all ;-)
   / Fuel bleeding issue. #5
I'm glad you got it going fine now.
I'd be puzzled by it all, once you bleed the air out & it runs for 45 minutes, the 'empty' line would seem to be a new issue, not 'left over ubleeded' deal?
Perhaps you didn't get something tight, and air was leaking in, while re-checking everything you got it tight & not letting air in any more?
Or some such.
--->Paul
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
Mac 3200 Chainsaw (A57454)
Mac 3200 Chainsaw...
2022 Behnke Trailer (A55973)
2022 Behnke...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A56436)
LIKE NEW 2023...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
