Fuel Bleed Screw
/ Fuel Bleed Screw #1
WhirldWorks
Rockdale, Texas
Massey Ferguson MF205
I have a Massey Ferguson MF205 tractor. I was recently bleeding the air out of the fuel line after a repair and although it didn't seem like I tightened it too hard, the dumb thing broke off. I have no idea where I can find a replacement, but any help would be appreciated.
/ Fuel Bleed Screw #2
You talking about #12 here?
/ Fuel Bleed Screw
Shaneard, unfortunately no. Its the bleed screw on the injector pump. It's a Kiki pump and the bleed screw is on the top right. I took it off so you can't see it in the picture, just the empty spot where it should be.
/ Fuel Bleed Screw #4
The P# for the bleed screw assembly is>> 104302-6640.. Diesel Kiki is now called Zexel..
You can look online or ANY injection shop will order it for ya..
The copper gasket P# is>> 026512-1540
OR you could go buy a 5mm bolt & gasket to fit the center..
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
New Quick Attach Power Spreader (A65579)
New Quick Attach...
2011 Ford F-750 Water Truck, VIN # 3FRPF7FA5BV653152 (A65563)
2011 Ford F-750...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
Killbros 390 Gravity Wagon (A66285)
Killbros 390...
