Oil & Fuel Fuel and temp gauges do not work on 2615
   / Fuel and temp gauges do not work on 2615 #1
ccgsail
Both the temp and the fuel gauges quit working on my 2615 gear with 245 hours. I have checked the fuses, and removed the dash looking for loose connection. Any other ideas? Thanks
   / Fuel and temp gauges do not work on 2615 #2
Mine didn't work on my 5525 when they dilivered it. I wasn't home at the time and called them the next day. They told me to tighten and clean the ground wire on the back of the alternator. It fixed it mostly but it still is intermittent. So they ordered me a new instrument panel and will come out and replace it when it comes in.
   / Fuel and temp gauges do not work on 2615 #3
My temp gauge isn't working on my 3525, but the fuel gauge works fine.
   / Fuel and temp gauges do not work on 2615 #4
did the answer below help the problem?
I have same issue, everything is working but the fuel gage and temp gage are not working
   / Fuel and temp gauges do not work on 2615 #5
For the fuel gauge, try draining your tank. After refilling it may begin to work again. Your temp gauge probably has a loose connection somewhere.
Krause 8200 Cushion Flex Disc (A52349)
Krause 8200...
Super Star Smithco (A50324)
Super Star Smithco...
2022 BARFORD TR8048 MOBILE SCREEN (A51242)
2022 BARFORD...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2009 Cat 140M VHP Motor Grader (RIDE AND DRIVE) (A50774)
2009 Cat 140M VHP...
Orthman 9300 4 row cultivator (A52128)
Orthman 9300 4 row...
