Oil & Fuel Fuel and temp gauges do not work on 2615
   / Fuel and temp gauges do not work on 2615 #1
ccgsail
Both the temp and the fuel gauges quit working on my 2615 gear with 245 hours. I have checked the fuses, and removed the dash looking for loose connection. Any other ideas? Thanks
   / Fuel and temp gauges do not work on 2615 #2
Mine didn't work on my 5525 when they dilivered it. I wasn't home at the time and called them the next day. They told me to tighten and clean the ground wire on the back of the alternator. It fixed it mostly but it still is intermittent. So they ordered me a new instrument panel and will come out and replace it when it comes in.
   / Fuel and temp gauges do not work on 2615 #3
My temp gauge isn't working on my 3525, but the fuel gauge works fine.
   / Fuel and temp gauges do not work on 2615 #4
did the answer below help the problem?
I have same issue, everything is working but the fuel gage and temp gage are not working
   / Fuel and temp gauges do not work on 2615 #5
For the fuel gauge, try draining your tank. After refilling it may begin to work again. Your temp gauge probably has a loose connection somewhere.
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2013 Ford Expedition XLT SUV (A50324)
2013 Ford...
Skid steer auger plate (A50322)
Skid steer auger...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2016 CATERPILLAR 335FL CR EXCAVATOR (A51242)
2016 CATERPILLAR...
