Oil & Fuel Fuel and temp gauges do not work on 2615
   / Fuel and temp gauges do not work on 2615 #1
ccgsail
Both the temp and the fuel gauges quit working on my 2615 gear with 245 hours. I have checked the fuses, and removed the dash looking for loose connection. Any other ideas? Thanks
   / Fuel and temp gauges do not work on 2615 #2
Mine didn't work on my 5525 when they dilivered it. I wasn't home at the time and called them the next day. They told me to tighten and clean the ground wire on the back of the alternator. It fixed it mostly but it still is intermittent. So they ordered me a new instrument panel and will come out and replace it when it comes in.
   / Fuel and temp gauges do not work on 2615 #3
My temp gauge isn't working on my 3525, but the fuel gauge works fine.
   / Fuel and temp gauges do not work on 2615 #4
did the answer below help the problem?
I have same issue, everything is working but the fuel gage and temp gage are not working
   / Fuel and temp gauges do not work on 2615 #5
For the fuel gauge, try draining your tank. After refilling it may begin to work again. Your temp gauge probably has a loose connection somewhere.
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
(INOP) CASE IH MAGNUM 180 TRACTOR (A50459)
(INOP) CASE IH...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
