I would talk to a different dealer if that is what they claim is wrong with your engine. A newer tractor engine like yours should be designed to run ultra low sulfur diesel without any problems. Are you talking to a salesman or mechanic. If mechanic, I would take my repairs to another place.ok 2007 B7800 dealer thinks my engine is bad from NOT USING additives.. so if I,m going to add stuff to the fuel whats best, I have a RTV and this 7800.
I would talk to a different dealer if that is what they claim is wrong with your engine. A newer tractor engine like yours should be designed to run ultra low sulfur diesel without any problems. Are you talking to a salesman or mechanic. If mechanic, I would take my repairs to another place.[/QUOTE
I agree, additives really shouldn't be required. I have used them in the past but mainly to prevent gelling, but as said above, if the fuel is blended correctly, it shouldn't gell either.
If it ain't broke don't fix it.
I agree, that's why I don't use any or see the need to use any!
SR
I will add in my opinion, there are some good reasons to add an additive. Storing fuel for a long time, gas seems worse than diesel though. The second, as someone above mentioned, diesel will grow algae. If algae is growing, there are additives that will kill it. Another is gelling in the winter, although if you buy blended fuel, your probably OK. When it gets really cold, as in near zero, I do add stuff to my truck and tractor for gelling.
