Fuel additive
   / Fuel additive #1
wforpm
MA
1951 Ferguson TO-30
Hello , I just picked up a 1950ish Ferguson TO-30 , is this something I would use lead substitute additive in or just Marvel mistery oil. And help would be great.
Tanks , Bob
   / Fuel additive #2
Lead additive is used to raise the octane rating and lube the valves...
That is a low compression engine, reg pump gasoline will work fine... the issue with valve lube should not be a problem. That engine should have adequate cooling at the valves. KennyV
Welcome to the fray... I just noticed that you are new to post... come back often, you even have your location indicated ...
   / Fuel additive #4
People need to use the search function....
   / Fuel additive #5
The N Fords had hardened valve seats. I would think that the Fergies, with their common heritage, would be likewise and not need the lube.
2008 DOOSAN G25 GENERATOR (A52472)
2008 DOOSAN G25...
2024 ATLAS CORPO PACF44 PORTABLE DEWATERING PUMP (A54757)
2024 ATLAS CORPO...
2013 John Deere 650K Crawler Tractor Dozer (A53421)
2013 John Deere...
UNUSED Polyester Arborist Outdoor Rope (A53117)
UNUSED Polyester...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
