Fuel additive
   / Fuel additive #1
wforpm
MA
1951 Ferguson TO-30
Hello , I just picked up a 1950ish Ferguson TO-30 , is this something I would use lead substitute additive in or just Marvel mistery oil. And help would be great.
Tanks , Bob
   / Fuel additive #2
Lead additive is used to raise the octane rating and lube the valves...
That is a low compression engine, reg pump gasoline will work fine... the issue with valve lube should not be a problem. That engine should have adequate cooling at the valves. KennyV
Welcome to the fray... I just noticed that you are new to post... come back often, you even have your location indicated ...
   / Fuel additive #4
People need to use the search function....
   / Fuel additive #5
The N Fords had hardened valve seats. I would think that the Fergies, with their common heritage, would be likewise and not need the lube.
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
New Holland B95 Backhoe (A50490)
New Holland B95...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
40ft Shipping Container (A52377)
40ft Shipping...
