FST vs. GST
/ FST vs. GST #1
mcnitt
Nevada City, California
Kubota GL3430
I have a grand L3430 with the full synchro transmission. I am completely satisfied with it, but I would like to know how the Glide shift transmission is different. I tried using the search function, but I couldn't get anywhere with it.
/ FST vs. GST #2
If he doesn't show up, check with Agrantina, he has a 3240 GST.
/ FST vs. GST #3
The GST is basically like a powershift transmission. You can either shift using the clutch or just push the gear shift lever to the next speed and it will shift by itself using an electro-hydrualic clutch pack. You can shift up and down and also from forward to reverse on some models without clutching, IIRC. Not quite like powershift on the big ag tractors, but pretty close.
/ FST vs. GST #4
Not sure how a Powershift transmission works but from reading a description they sound different then the GST since the Kubota only has clutch packs for forward and reverse and you must clutch fully before shifting.
The GST is a synchronized gear transmission with hydraulic plungers shifting the forks in the transmission. The newer GST such as I have on my L3130 use solenoid valves controled by a ECU to do the gear selection and clutch feathering using the hydraulic clutch packs. Since you are not limited by having shifter forks going to a shifter there is a little more flexability and that is why the GST has 12 forward and 8 reverse, although you could have 12 reverse I think the put the limit at the 8 slower gears for safety.
David Kb7uns
Used Landpride GR1525 Stump Grinder
Used Landpride...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A  SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
RAIN FLO 1200 WATER WHEEL TRANSPLANTER (A63291)
RAIN FLO 1200...
Bell 1600 Gallon Nurse Trailer (A63688)
Bell 1600 Gallon...
2018 FREIGHTLINER CASCADIA  125 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
