Frozen Tilt Steering on TC40D
   / Frozen Tilt Steering on TC40D #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
I must have gotton moisture in the tilt steering mechanism on the TC40D. The latch will not hold the wheel in place. It moves up and down. I sprayed a little WD40 into the area where it pivots and the latch freed up. However, when I went out to use the tractor last night it was frozen again.
I trust the moisture problem is in the return spring.
Any suggestions?
   / Frozen Tilt Steering on TC40D #2
</font><font color="blue" class="small">( I sprayed a little WD40 into the area where it pivots and the latch freed up. )</font>
IF it refroze after the WD40, you might try putting a little anti-freeze around the actuator pin. The WD40 evaporates and/or separates from water because it is oily. The antifreeze should mix with any water and keep it from freezing. ...just a suggestion. I've never had trouble with mine in the much warmer TX weather.
   / Frozen Tilt Steering on TC40D #3
I remember a thread about this before - it was water in the piston top or something like that. The problems existed for people who stored them outside. One solution, besides a tarp, was tipping the seat forward to shelter the steering wheel. I also vaguely recall a service bulletin/retro kit for the older class III steering tilt mechanisms...???
Mark
My tractor is always stored inside. I was using if a few weeks ago in a light rain. Now I have the curtis cab on it so there shouldn't by any additional moisture to contend with.
I hope to have my 15,000 btu heater up and running by the end of the weekend so that should help to thaw it if it freezes again. Of course I may still have the problem until the cab warms up.
I spoke with my NH dealer (Olstad Implement in Chatfield, MN) and he says if it acts up again to give him a call. These guys have been great to deal with and I don't doubt they will take care of the problem.
   / Frozen Tilt Steering on TC40D #5
Glad to hear your dealer is very helpful. There was a service bulletin and now is a plastic cover that goes over the top of the shock where the actuator piston is. The cover has been out for quite a while now so your dealer should know what it is. /forums/images/graemlins/smile.gif
   / Frozen Tilt Steering on TC40D #6
techinNY,
Would you know a part number for this piece or the service bulletin #? I just replaced my tilt shock yesterday and while I got it off without removing the steering wheel, I'd sure like to avoid that work again. The lower pin is a real bear.
Peter
   / Frozen Tilt Steering on TC40D #7
I'm sorry I don't know the part #, If I think about it I will look it up Monday and get back to you.
   / Frozen Tilt Steering on TC40D #8
I haven't forgot about getting the part #, just did not have time the three days I worked last week. I'll try to get it this week.
   / Frozen Tilt Steering on TC40D #9
The part# for the plastic cover is 86401203. This part is listed for all the deluxe compact tractors from the 1530 on up to the TC45D.
2017 PJ TRAILER 20' T/A TRAILER (A58216)
2017 PJ TRAILER...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Club car (A56859)
Club car (A56859)
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
