Frozen Tilt Steering on TC40D
   / Frozen Tilt Steering on TC40D #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
I must have gotton moisture in the tilt steering mechanism on the TC40D. The latch will not hold the wheel in place. It moves up and down. I sprayed a little WD40 into the area where it pivots and the latch freed up. However, when I went out to use the tractor last night it was frozen again.
I trust the moisture problem is in the return spring.
Any suggestions?
   / Frozen Tilt Steering on TC40D #2
</font><font color="blue" class="small">( I sprayed a little WD40 into the area where it pivots and the latch freed up. )</font>
IF it refroze after the WD40, you might try putting a little anti-freeze around the actuator pin. The WD40 evaporates and/or separates from water because it is oily. The antifreeze should mix with any water and keep it from freezing. ...just a suggestion. I've never had trouble with mine in the much warmer TX weather.
   / Frozen Tilt Steering on TC40D #3
I remember a thread about this before - it was water in the piston top or something like that. The problems existed for people who stored them outside. One solution, besides a tarp, was tipping the seat forward to shelter the steering wheel. I also vaguely recall a service bulletin/retro kit for the older class III steering tilt mechanisms...???
Mark
My tractor is always stored inside. I was using if a few weeks ago in a light rain. Now I have the curtis cab on it so there shouldn't by any additional moisture to contend with.
I hope to have my 15,000 btu heater up and running by the end of the weekend so that should help to thaw it if it freezes again. Of course I may still have the problem until the cab warms up.
I spoke with my NH dealer (Olstad Implement in Chatfield, MN) and he says if it acts up again to give him a call. These guys have been great to deal with and I don't doubt they will take care of the problem.
   / Frozen Tilt Steering on TC40D #5
Glad to hear your dealer is very helpful. There was a service bulletin and now is a plastic cover that goes over the top of the shock where the actuator piston is. The cover has been out for quite a while now so your dealer should know what it is. /forums/images/graemlins/smile.gif
   / Frozen Tilt Steering on TC40D #6
techinNY,
Would you know a part number for this piece or the service bulletin #? I just replaced my tilt shock yesterday and while I got it off without removing the steering wheel, I'd sure like to avoid that work again. The lower pin is a real bear.
Peter
   / Frozen Tilt Steering on TC40D #7
I'm sorry I don't know the part #, If I think about it I will look it up Monday and get back to you.
   / Frozen Tilt Steering on TC40D #8
I haven't forgot about getting the part #, just did not have time the three days I worked last week. I'll try to get it this week.
   / Frozen Tilt Steering on TC40D #9
The part# for the plastic cover is 86401203. This part is listed for all the deluxe compact tractors from the 1530 on up to the TC45D.
John Deere 5075E (A53317)
John Deere 5075E...
2018 Ram 5500 4x4 Crew Cab Utility Flatbed Truck (A55973)
2018 Ram 5500 4x4...
LOT: (48) 2.5 Gallons of Star Fire Diesel Exhaust Fluid (A59076)
LOT: (48) 2.5...
Black Metal Roof Panels (A55758)
Black Metal Roof...
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2018 RAM 2500 (A58214)
