Frozen Hood Latch on L3010
   / Frozen Hood Latch on L3010 #1
Anonymous Poster
Epic Contributor
Short but irritating problem-I can’t get the drivers side (left or the clutch side) hood cover off. The latch is frozen. I have put 4 hours on the tractor, it is brand new, and have sprayed it with liquid wrench penetrating oil, but no movement of the latch.
I feel like a complete dope having the dealer have to come out for something that stupid, but I do not want to break the handle off.
How can I free this without breaking anything?
Any ideas?
Thank you!
   / Frozen Hood Latch on L3010 #2
Push in on the cover with one hand while turning the lever with the other. This should relieve the pressure on the latch so it will turn. If that fails use a BFH!
   / Frozen Hood Latch on L3010 #3
You think getting the engine cover off is tough? What til you try to put it back on. One of my covers fits so tight I have to put a shoulder against the cover and push hard while turning the lever. On the other side of the tractor, no problem. Go figure.
   / Frozen Hood Latch on L3010 #4
You might try removing the easily removed side cover and see if you can gain access to see what is wrong with the latch on the side that won't open. I know the motor is in the way but it might help. When the side panels are installed the latch can be turned the wrong way and the latch can go over center. They are tricky to latch but they are tight enough so the side panels don't rattle.
   / Frozen Hood Latch on L3010 #5
Thanks Dozernut!
Worked like a charm.
I think it was just new and hasn't been worked enough. I put some grease on the latch and eveything seems to be working well!
   / Frozen Hood Latch on L3010 #6
Your welcome, enjoy your new tractor!
LOT: (9) Tires & Rims: 275/80 R22.5, 275/70 R22.5 and other sizes (A59076)
LOT: (9) Tires &...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A56858)
2015 Ford F-550...
2017 CATERPILLAR 304E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2012 MACK GU (GRANITE) CAB & CHASSIS (A56129)
2012 MACK GU...
2013 HYUNDAI Veloster (A56859)
2013 HYUNDAI...
