Frozen Hood Latch on L3010
   / Frozen Hood Latch on L3010 #1
Anonymous Poster
Epic Contributor
Short but irritating problem-I can’t get the drivers side (left or the clutch side) hood cover off. The latch is frozen. I have put 4 hours on the tractor, it is brand new, and have sprayed it with liquid wrench penetrating oil, but no movement of the latch.
I feel like a complete dope having the dealer have to come out for something that stupid, but I do not want to break the handle off.
How can I free this without breaking anything?
Any ideas?
Thank you!
   / Frozen Hood Latch on L3010 #2
Push in on the cover with one hand while turning the lever with the other. This should relieve the pressure on the latch so it will turn. If that fails use a BFH!
   / Frozen Hood Latch on L3010 #3
You think getting the engine cover off is tough? What til you try to put it back on. One of my covers fits so tight I have to put a shoulder against the cover and push hard while turning the lever. On the other side of the tractor, no problem. Go figure.
   / Frozen Hood Latch on L3010 #4
You might try removing the easily removed side cover and see if you can gain access to see what is wrong with the latch on the side that won't open. I know the motor is in the way but it might help. When the side panels are installed the latch can be turned the wrong way and the latch can go over center. They are tricky to latch but they are tight enough so the side panels don't rattle.
   / Frozen Hood Latch on L3010 #5
Thanks Dozernut!
Worked like a charm.
I think it was just new and hasn't been worked enough. I put some grease on the latch and eveything seems to be working well!
   / Frozen Hood Latch on L3010 #6
Your welcome, enjoy your new tractor!
(12) TOPPING JARS (A58374)
(12) TOPPING JARS...
LOT: (80 approx.) Gallons of Chevron Delo 400 XLE SB SAE 15W-40 Synblend (A59076)
LOT: (80 approx.)...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2016 Husqarvana YTA22V46 46in Riding Mower (A56859)
2016 Husqarvana...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56435)
2018 John Deere...
