Frozen fill dirt on water line?
   / Frozen fill dirt on water line?
Is there any type of roll insulation that I could use for my 200 ft of depressed ground? My trench is about 6in wide - just thinking if could roll something out as a temporary measure. They now aren't turning the water on until tomorrow when it's a balmy 25 haha
   / Frozen fill dirt on water line? #32
I'll say no- but anything is possible. The insulation we were discussing would placed on top of the pipe and be installed prior to backfill. You may be over thinking this or doubling your efforts. Dirt is the final solution so anything you do now will get redone at some point if it's not dirt. I'm just trying to save you time and money.
If you can't get dirt on it until spring don't drive or disturb the snow in those areas- it will help insulate it.
If you get an unusual cold snap run a bit of water during those few days. I'm guessing that would amount to less than $10 worth of water which is far less than any of the other temporary solutions.
Thanks - I was hoping to do that - but wasn't sure how risky that would be. We are supposed to get into the mid 30s for most of next week. Hopefully the ground will thaw enough for me to add some dirt and use my box blade
   / Frozen fill dirt on water line? #34
A trick we used in the far north was to put down a foot wide strip of 2" thick foam board insulation. First, it cushioned the fall of the dirt and second was the insulation. Pick the big rocks out but we never had a problem doing it this way.
Good trick!
Or local building inspectors will approve 1' less depth for every 1" (R5) of rigid. We can use a max of 2". Normal depth here is 44-48" so we could go to 2' plus 2" of rigid in an area with a large bolder or similar that prevented digging to the standard depth- very rarely used but a vital trick!
Doing underground in my previous location we would use "sand" or "base". Then in my current location they use "crushed stone" or "stone dust".
I'd assume the concern is larger stone that could damage the pipe? Like 1/2" and above?
We had a 7 ft frost line and I put down two layers of 12" wide by 2" thick blue foam at five feet down. Never a problem and I have seen guys do similar at 4 or 5 feet. Temps could go to minus 30 or minus 35 but the issue was that it stayed cold from November through spring with little chance to warm up.
By the way, I have been told that frost only travels up and down and not sideways so cutting extra wide widths of foam wasn't necessary. That stuff really holds the heat and the running water provides some. If you care, pushing snow over a water line keeps the frost out too.
   / Frozen fill dirt on water line? #35
You are on the right track! It will work out fine. Enjoy the new building.
   / Frozen fill dirt on water line? #36
What no one else has mentioned is that frozen ground is as hard as concrete. Just like you wouldn't put rocks directly on the line, you shouldn't put chunks of frozen dirt either. If the pit is 2x3 feet, six inches of sand is three cubic feet, or about 300 pounds. What I would do is go to Home Depot or Lowes -- where they keep the building supplies indoors -- and buy six 50-lb bags of sand. That will protect the pipe. You can then pile chunks of frozen ground over it. That will keep it from freezing. When the ground thaws the chunks will melt and settle, you'll have to fix it up then. I doubt you'll be able to do any landscaping until spring anyway.
   / Frozen fill dirt on water line? #37
I don't know what everyone was thinking but felt that almost everyone understood these issues and suggested similar solutions to yours. Adding the insulation as many suggested solves the chunky frozen dirt problems and helps to capture ground heat. The OP mentioned buying the bags of top soil that he was warming up in the house.
Just wanted to give a final update - it worked out perfect. The plumbers happened to be turning on the water while the septic tank guys were still there installing my tanks - plumbers checked the line and then the septic guys filled the pit with some fresh hot dirt from their dig - it was nice and steamy :cool2:
CATERPILLAR LR119 HYD LANDSCAPE RAKE (A52709)
CATERPILLAR LR119...
LandPride AFM4216 (A57149)
LandPride AFM4216...
(15) UNUSED IRANCH 94"X41" FLOOR PROTECTION MATS (A58376)
(15) UNUSED IRANCH...
2004 PSI M413XT Motor Grader (A56857)
2004 PSI M413XT...
(2) 5' TRAILER RAMPS (A58375)
(2) 5' TRAILER...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
