airbiscuit
Super Member
- Joined
- Aug 28, 2004
- Messages
- 7,492
- Location
- NW Wisconsin
- Tractor
- New Holland T2310 (40hp), Kubota L3010 GST, New Holland TC21DA *** Previously - Farmall H, 1941 John Deere B, Shibaura SD1500, John Deere 850, Bobcat 642, New Holland 1925
As I think about it, it isn't necessary to take the plugs out (I was thinking it would be easier to pull without fighting compression). The object is to dramatically change the speed between the clutch (transmission side) and engine (flywheel side). Like I said, my friend started theirs in high gear, ran it as fast as they could with the clutch pushed in , and kept mashing the brakes. After a couple iterations, it freed up.
If you open the document in post #7, it says
"Here are a couple of other techniques to break the clutch free and save splitting the tractor:
If the clutch has not been stuck for long you can probably get it unstuck by jacking up one wheel and with the tractor out in the open or with the bumper against a big tree with no slack between the two. Start the tractor and with it in high gear (4th) with the clutch pedal tied down and the engine RPM all the way open, drop the jack so that the wheel hits the ground suddenly and if it doesn't come loose the first time try it a couple more. Most of the time it will come loose if in fact it is stuck and not damaged in some way" Anonymous
That looks fraught with danger to me, and I wouldn't recommend it.
