frozen block? just to dang cold.
   / frozen block? just to dang cold. #1
Kendrick
Vermont
DK45S(Cab)
diesel 45 yester day was probably -20 and nothing started. the kioti starter clicked a bunch and didnt move the parts. any suggestions on how to get it back up and running again? bad/week battery is known.
Any one have suggestions for block heater? and maybe trany heater.
   / frozen block? just to dang cold. #2
When it's that cold outside. You need to bring it in the house where it's nice a warm. :laughing:
   / frozen block? just to dang cold. #3
What are your options shed , barn , power y/n ,lockable. The problem is if you bring them in they want to HOG the REMOTE TV .
Craig Clayton
   / frozen block? just to dang cold. #4
Time for a block heater for sure...also Powerservice for the fuel...I would tarp and add some kind of portable heat(salamader ect).Block heater should suffice.
   / frozen block? just to dang cold. #5
Just leave them running once started, you could get a small generator and make power overnight off your PTO. LOL, Lots of transport truck up north almost never get shut off in the -20 range.:D
   / frozen block? just to dang cold. #6
   / frozen block? just to dang cold. #7
I bought my DK45 in 2006 and it came with a block heater. The plug in is on the left side just forward of the cab. I plugged it in a couple of times the first winter, but haven't done so since...it seems to start up just fine without it. Minus 20 C (a few degrees below zero F) or so is about as cold as it gets here, though.
BOB
   / frozen block? just to dang cold. #8
So far, cross my fingers, my DK40 has started fine even at -25. I run the glow plugs a little longer before hitting the starter.
   / frozen block? just to dang cold. #9
Try a heat gun for removing paint etc. or a high powered hair dryer to warm up the starter. Then go to a block or radiator hose heater once things come back to workable temps.
Try to not fry the starter- just heat it enough so it will turn over the engine. At those temps you may have fuel issues too. Keep away from the fuel bowl with any type heater. You might be able to wrap the starter with pipe heat tape long enough to get her started.
They also make dipstick heaters too.
   / frozen block? just to dang cold. #10
It didn't have anything to do with the cold but I had that happen once to my tractor where it just clicked repeatedly and didn't start. I put the charger on the battery to test it and it was at 95%. I took off both terminals and cleaned them which didn't help. I called my dealer and the tech suggested I take the ground cable off where it connects to the frame and clean that contact. If it has a bad ground, the battery cannot send as much "juice" to the starter.
I cleaned the rusty bolt and metal it was connected to and that solved it! It started right away and hasn't given me a problem since. I now clean that ground every year.
2018 CATERPILLAR 289D SKID STEER (A52709)
2018 CATERPILLAR...
2015 Freightliner Cascadia SLEEPER (A58017)
2015 Freightliner...
2011 Peterbilt 365 Altec AC38-127S 5-Mast 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Truck (A56858)
2011 Peterbilt 365...
Kenworth T/A Sleeper Cab Truck Tractor (A55973)
Kenworth T/A...
LOT: (1) Steel Plate Sheet, 1/4" Thick, 48" x 96", (1) Steel Plate Sheet, 1/4" Thick, 41" x 96" (A59076)
LOT: (1) Steel...
1995 NEWTON CROUCH PULL SPREADER (A58375)
1995 NEWTON CROUCH...
