Ballast Front Weights
   / Front Weights #11
spd163,
I have a New Holland TC18, the manual calls for a maximum of 3 weights @ 57 lbs each = 171 lbs. I'm using 2 weights @ approx. 90 lbs. each = 180 lbs.
I have a Woods 5' rear finish mower weighing in at approx. 600 lbs. and a Woods 4' rear rotary mower weighing in at approx. 500 lbs. and I don't have a problem using either one.
My tractor was delivered with the finish mower and one 57 lb. weight on the front. When I informed the dealer that it was really light in the front end, they provided me with the larger weights at no charge. I believe that since they told me that my setup would work OK, that they wanted everything to be "OK".
I do have filled rear tires, since Thanksgiving, but not filled front.
Good Luck, JimBinMI
   / Front Weights #12
Rch--You're right. I hadn't thought about the possibility of tipping sideways. I don't have a FEL so any weight I'm carrying is always on the back and never above rear-axle height. Even so, weird things can happen. Thanks for the warning. Besides, I really do feel silly leaning out over the steering wheel to get some extra weight up front. Part of it is laziness, too; my quick hitch extends implements further behind the tractor and provides extra leverage. If I would take off the quick hitch when I use the scoop that might make a significant difference.
   / Front Weights #13
I used water; it was during the summer. I removed the water in the fall, right before I got a loader(and before it had a chance to freeze!
You may want to do a search on ballast or weight; the subject has been discussed here numerous times in the past.
RobertN in Shingle Springs Calif
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
SUV (A59231)
SUV (A59231)
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
3650 (A47477)
3650 (A47477)
