Front weight holder
   / Front weight holder #1
CircleJFarm
Anyone have any ideas on a good setup for storing front tractor weights?
Thanks!
   / Front weight holder #2
i have a big angle iron bumper, and just cast some concrete weights to mount to it using carriage bolts cast into the concrete.
soundguy
   / Front weight holder #3
I just built a front weight ballast box for my JD 3032E. It is built out of 2 inch angle iron and mounts to a 2 inch reciever hitch that I added to the front of the tractor. The box will hold 14 - 4 " x 8" x 16" solid concrete blocks for a total of 350 lbs. You can add more blocks to it also for more weight if you used a ratchet strap to hold them in place. Each block weighs 25 lbs. I will post some pictures of the build soon.
   / Front weight holder #4
I think he is asking a good convenient way to store them when not on the tractor. What type of weights do you have, that might help give someone a idea of a way to store them.
   / Front weight holder #5
anything from a pallate to a rack on the wall.
soundguy
Crown RM6025-45 4,500 LB Stand-On Electric Forklift (A59228)
Crown RM6025-45...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A61307)
Case Wheels for...
2020 BOBCAT MT55 STAND-ON SKID STEER (A60429)
2020 BOBCAT MT55...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
2014 TAKEUCHI TL12 SKID STEER (A60429)
2014 TAKEUCHI TL12...
