Front Weed Wacker
   / Front Weed Wacker #1
mikell
Anyone built a cutter of any sort to cut under electric fences.
Thanks
Mikell
   / Front Weed Wacker
Yea thats generally what I'm looking for. I have an old 18hp rider that gets all the dirty work and want to build something quick attach possibly even 12 volt. Got all winter to play.
Thanks
mikell
   / Front Weed Wacker #4
What about a side-mounted Hedge trimmer? Maybe have it spring loaded so it won't break if it rams a post???
   / Front Weed Wacker #5
Roundup Ultra.
Chemical weeding, once a year. Quiet and dependable. No fumes, no gasoline and guaranteed kill.
   / Front Weed Wacker #6
I saw a 12Volt string trimmer at one of the shows I attended, darned if I can remember who it was though. It attached the the side of your mower deck and was operated by a foot switch. Spring loaded as well. Anyone else remember seeing this?
   / Front Weed Wacker
Have a Gordons Setter with liver problems that somewhat may be related to spraying so I'm going to try and cut back on it.
mikell
   / Front Weed Wacker #9
My 16HP riding weed wacker
Here's a fence trimmer I build from a large wheel gas powered string trimmer. It clips on to the mower deck mounts with two pins in about a minute. The original had a 6HP engine, so I geared it up a little and usually cut at about half throttle. The mower height lever raises and lowers it, although it could use more range than the mowers 4 inches. Sure does cut great though. It's spring loaded and pivots around fence posts.
   / Front Weed Wacker #10
Re: My 16HP riding weed wacker
I let it stick out far enough to trim ditches without getting the tractor too close. It needs more vertical articulation, so I think I'll add another hinge so it can float along the ground better.
   / Front Weed Wacker #11
You can see the return spring that lets it follow fence posts. The white plastic guide on top is an HDPM plastic cutting board. I use the original Ariens belt clutch as a spring load belt tensioner. The belt doesn't have a lot of tension, but it takes a lot to make it slip.
BTW, I had originally mounted it off the 3 point hitch on my 4310 (using the original 6HP engine). That was a disaster. This setup works really well and is very easy to use. It works better than I ever thought it would. Highly recommended.
   / Front Weed Wacker #12
That's a very clever design. I'd bet you could sell all of those you could build. With a vertical adjustment, you could call it the "deluxe" model and get a premium price. /forums/images/graemlins/shocked.gif Great job! /forums/images/graemlins/cool.gif
   / Front Weed Wacker #13
one of the best and most original ideas that I've seen in a while. I personally would like to see more detailed pics, as they say imitation is the most sincere form of flattery (or something like that) Might not be a bad idea to check on patent or at least maybe approach someone who would know of these things.Probaly would not be too hard to manufacture, or at least sell the basic design to an implement man. co.
   / Front Weed Wacker #14
Very slick! /forums/images/graemlins/cool.gif
BTW, I also like the flagpole visible in the backview. Be a great place to stick my UNC Tarheels flag for victory laps around the yard! /forums/images/graemlins/grin.gif
   / Front Weed Wacker #15
I think that\'s for his Umbrella!
But you could put a flag there too.
I might borrow that idea to mount an umbrella holder on my rops...........
   / Front Weed Wacker #16
The 'flagpole' is a John Deere umbrella mount. They make a bunch of different mounting styles with a nice quality folding umbrella. I mounted this one to a tab I welded onto the little Class 1 receiver hitch. The umbrella lifts out easily when trimming under trees or doing silly things like converting your tractor into a weed wacker. I you live where the sun shines, I highly recommend it.
   / Front Weed Wacker #17
This is my third iteration, and the first one that actually works as well as I had hoped. Here's a shot of the mount that hangs from the stock JD mower attachments with two hitch pins. It is really quick and easy to switch from mower to trimmer.
   / Front Weed Wacker #18
Here's a shot of the front end of the mount. It hangs on the stock JD front mower hanger, and is made from a 2x2" cross tube, with 1/4x2" rails. It weighs very little. For the trimmer spindle, I used an Ariens big wheel trimmer head, without the handle, wheels and engine (anyone need any spare parts, I got em!) It pivots on the bolt visible just ahead of the return spring so that it folds out of the way when you come up to a building or fence post.
   / Front Weed Wacker #19
</font><font color="blue" class="small">( Here's a fence trimmer I build from a large wheel gas powered string trimmer. It clips on to the mower deck mounts with two pins in about a minute. The original had a 6HP engine, so I geared it up a little and usually cut at about half throttle. The mower height lever raises and lowers it, although it could use more range than the mowers 4 inches. Sure does cut great though. It's spring loaded and pivots around fence posts. )</font>
That's just about exactly what I need to trim the sides of my driveway. I think Jim is right, you likely could sell as many as you could build.
John
   / Front Weed Wacker #20
I need to find some sheet rubber to make a flexible top belt cover. The spindle and the orange part is all that is left of the Ariens, and I'll probably get rid of the orange part next, so buying a new trimmer was kind of an expensive way to get to where I've ended up, but the results are worth it. I've got about a mile of fence and ditch trimming, plus two buildings to trim around, and it's great to sit in the shade of my umbrella instead of hacking away with a hand-held.
If you'd like any more info, let me know.
John
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
2008 V.E. ENTERPRISES 130BBL VAC TRAILER (A58214)
2008 V.E...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
