Front-to-rear gear ratios
   / Front-to-rear gear ratios #1
froggy
Cooke County, Texas
JD4320 with TNT, electric diverter, cruise control and air suspension seat.
Found this infomation on the JD web site:
5105 / 5205: 0.751
5200 / 5210 / 5300 / 5310 / 5400 / 5410 / 5500 / 5510 / 5220 / 5320 / 5420 / 5520: 0.741
5310N / 5320N / 5400N / 5420N / 5500N / 5510N / 5520N: 0.654
Have not been to find the same information on the 4000 series.
   / Front-to-rear gear ratios #2
In a pinch you should be able to calculate this by measuring your tires. Just measure the diameter of the front tires and divide by the diameter of the rear tires - they both need to be rotating such that they move the same distance per unit of time so the ratio of their circumferences should be equal to the gear ratio.
Just thought it was interesting that John Deere didn't publish this information for compacts. Most dealers I've called don't seem to know the ratio for the 4720 and 4520.
   / Front-to-rear gear ratios #4
I think it's because Deere knows that we compact tractor owners are smart enough to figure it out by ourselves :)
Not sure why there are fewer specs the lower down the food chain you go (for example, the 4000 series has a noise spec but I don't think the 2520 does). It could be to keep things simpler, or possibly because the larger tractors are more likely to use aftermarket wheels. I've always wanted an excuse to get Mattracks but they cost more than my tractor and I don't REALLY need them...
Komatsu PC88MR-8 (A47477)
Komatsu PC88MR-8...
2013 International Dura Star (A53314)
2013 International...
2012 Freightliner M2 106 Asphalt Pothole Patcher Truck (A51692)
2012 Freightliner...
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2008 Ford F-350 Service Truck (A55788)
2008 Ford F-350...
