Tires Front tires plowing the ground
   / Front tires plowing the ground #31
Spiveyman,
It appears that you have what is called a F2 front steer tire. When I bought my Kubota I told the dealer that I was eventually going to put on a loader. He suggested a multi-rib or 4 rib tire like these: Titanï½® 2006 Tire catalog or these: Titanï½® 2006 Tire catalog .
They work just as well turning when using a disc, bushhog, etc... , but are much friendlier on the yard and gravel in the driveway. They also have much better flotation when I have the bucket loaded with dirt/gravel.
Chris
Just got back from the farm. As usual I got to do very little of what I wanted to do because of something bovine-related.
This time two of the neighbor's bulls had busted into my fields. Guess they thought the horns on my cows were.... uh.... (trying to stay family friendly) let's just say attractive. ;) Either that or they liked the fact that I actually have grass. So I spent lots of time repairing the other line fence. :( Instead of playing with my tractor.
I did get to experiment with the steering brakes a bit. Sandmand, wish I'd seen your post first, would have practiced in that neighbor's fields. :D That could pay him back for the grass his bulls ate. Anyway, it does swing that front end around, but I haven't acquired the knack yet for doing it naturally.
I agree, those scuffs aren't horrible out in the fields, there's lots of field compared to the scuffs, but in the areas I drive a lot, around the barn mostly, it's getting really bad (to me).
I didn't have time to fool with the spacing, but I did check out how to do it. Seems pretty easy, the axle has holes, loosen bolts, slide out - right? The rods that actually turn the wheels have the same kind of adjustment. Very cool. One of these days when I get all the fences fixed I might actually get to mess around with that.
Thanks for the pointers Rob on blocking the rears and the belly. I want as much Murphy repelant as possible.
And finally, firefighter, those tires seem much more reasonable, but man I hate to spend money on new tires when these are so new. How long does it take to wear out a set of front tires when you only drive on soft ground, no pavement? I'm guessing a LONG time huh? Maybe I should start taking the tractor to the grocery store - afterall the fuel bill would probably be better than my truck!! :eek:
Is there a market for selling the fronts that I have? The guy I bought the tractor from put new rubber all the way around, so I don't even have a clue how much those things cost.
   / Front tires plowing the ground #33
heheh If you see circles in my field... its not ailens.. its me learning to drive ;)
sounds like a winter project for me :D Learn the field and how to break turn...
   / Front tires plowing the ground #34
Hey Spiv,
If you're using the fel to dig or something, it's a mess anyway. If you're dragging your super nice boxblade, it'll cover up the ruts, right? What do you do going forward besides that anyway? Do you have a mower yet?
I was thinking does your tractor steer easier and leave less ruts going backwards? I mean the tire ruts from the front wheels ... are they as bad when you back up and turn? Try that and just start driving around in reverse until it gets dry again. As little as you use that thing it wouldn't matter. LOL ... Plus you could keep an eye on your carry all and see when something is going to fall off.:D
(You know I'm pulling your leg.:) )
   / Front tires plowing the ground #35
Spiveyman,
15 years from now when you wear out the front tires you have you can buy yourself a set of 4 ribs. Honestly I have used my tractor pretty hard in the woods the past four years and my front tires still have the same tread depth as new, but with cuts and abrasions from running over rocks, trees, etc.... I don't expect to wear out my front tires, but wouldn't put it past myself to ruin one and have to buy another.
Chris
   / Front tires plowing the ground #36
I had already been informed of his new tires prior to this post, so I KNEW he wasn't going to want to change them. I noticed they were the wrong ones for what he was using them for, but figured I would have done the same thing he is doing, which is trying to get some use out of them. I think I would keep an eye out for some used ones, of a better size/tread pattern and if a deal comes along, grab them. You will probably have to buy rims also, so you can get them at a deal, and stash them away until you cut one of the existing tires. Then, instead of being down waiting on the new tire rubber to be harvested at the rubber tree plantation, you can just put on your backup set and be back to work in an hour.
David from jax
HA! :D Good one!
I wish I was doing more of that work these days, but sadly I'm not. I do have a rotary cutter, but my automatic grass trimmers are doing a heck-uv-a job on the grass. Moooo. Mostly these days it cattle related work, moving hay, driving T-posts, ripping out bad fences... etc.
I'm starting to feel accepted here... in my family you're not loved if no one'd giving you a hard time. Point in fact, it does turn easier in reverse, and it does not tear up the grass. I started driving everywhere in reverse but got a crick in my neck! :D ;)
I logged several hours on my tractor yesterday, and never dropped a thing off the carry all! :) I put lots of stuff in the FEL though.
sandman2234 said:
...I KNEW he wasn't going to want to change them. I noticed they were the wrong ones for what he was using them for, but figured I would have done the same thing he is doing, which is trying to get some use out of them.
For real? Wrong ones huh? That's kind of what I've been looking for in this thread. I mean, if they are just straight up the wrong thing for what I need, I can take it, tell me (which you just did - thanks). It doesn't take long to figure out I'm flying by the seat of my pants and have very few clues about how things should be done. When I got the tractor the tires looked odd to me compared to what I'm used to, but I'm used to a 3910. This is a different beast. I just didn't know what should be on there. I think that's motivation for me to actually do something about it, like try to find a decent deal on a different set.
sandman2234 said:
...instead of being down waiting on the new tire rubber to be harvested at the rubber tree plantation...
LOL :D How true it is.
   / Front tires plowing the ground #38
I don't believe there is a whole lot of science to this one. When you turn a tractor, or anything, the momentum wants it to go straight. If the tire is leaving marks then it's slipping on the ground slightly. If you are on concrete and it leaves a mark there is still pressure that the tractor wants to go straight. The rear driving wheels are pointing straight the whole time. And on the 3 rib tire the center rib is proud of the outer 2 so a lot of the pressure is in that center rib and it's cutting the ground. My little L with the same tire does the same thing. If I put on the flat turfs it's better. But if I speed up...I put more pressure on the outside of the tire and it'll still cut the ground a little. On mine the outside tire is the one that makes the marks, IMO it's because the outside tire is traveling faster and has more pressure on it to turn the tractor, car, whatever. My guess is there is also more weight being applied to the outside tire.
Slow down, make a bigger turning radius and it'll help some. Changing the tire to a car tire will help. There are also several types of ribbed tires. Look at that center rib on the picture!!
3 ribs are a farm tire designed to be run in plowed soil. But they are cooler looking than a car tire IMO. :D
You guys into NASCAR should know this, all that rubber on the road from trying to get a 3000# car to turn at 200+ mph. It's gonna leave a mark!! :D I also read a few sentences about Ackerman. Maybe I didn't read enought but I don't want to set up my tractor to only make left turns better. :)
   / Front tires plowing the ground #39
All kidding aside, there is no way I would change out those tires, unless I came across a deal of the century, which is what it would take right now anyway, lol! The controling factor in my opinion isn't the marks your making on the ground, but how it is handling the weight when you load the bucket. I didn't see it posted, but I am sure you probably have jacked the air pressure up in those front tires to at least max air pressure or more, and if you had a wider set, it would probably handled the weight a little better. Would depend on the tire also, but the more air in the donut, the more it will hold. You can move the world with 40 pounds of air pressure, but it takes an awfully big area of it to do so.
David from jax
RobJ said:
...3 ribs are a farm tire designed to be run in plowed soil. But they are cooler looking than a car tire IMO.
Yep - way cooler! :cool: I wouldn't go to a car or truck tire, it'd be a multi rib deal. It still has to look like a tractor!!!
RobJ said:
...I also read a few sentences about Ackerman. Maybe I didn't read enought but I don't want to set up my tractor to only make left turns better. :)
As a die hard NASCAR fan I would feel remis if I didn't mention that two wrongs don't make a right, but three lefts do. :D By the way, there are two road courses. There's a time for turning right too.
Or the lotto, but I'm not likely to win since I don't play the lotto, guess I'm stuck with looking for a deal. :rolleyes:
I have not changed the pressure in the tires and so far haven't really pushed the FEL capacity. I'm assuming a full scoop of dirt + rocks isn't anywhere near that, nor is a round bale. I probably won't get in that realm of lifting until I get a back hoe and can start taking out trees for a couple of projects. And that day seems farther and farther away.... :(
2013 JCB 3CX Extendahoe Loader Backhoe (A55973)
2013 JCB 3CX...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
PALLET OF KUBOTA L3902 HOOD, DASH (A57192)
PALLET OF KUBOTA...
Bush Hog 7007 3pt Grader Blade (A53317)
Bush Hog 7007 3pt...
2015 Goose Neck Cattle Trailer (A53317)
2015 Goose Neck...
2016 Chevrolet Tahoe SUV (A54815)
2016 Chevrolet...
