Tires Front tire slipped off rim
   / Front tire slipped off rim #1
Axman
On a muddy hillside the other day the front tire on my GF2300 slid sideways and the tire went flat immediately. I took the tire off and aired it up and it seems just fine but is there any other things I might need to know in this weird happenstance? I've driven the tractor some since then and it seems fine.
   / Front tire slipped off rim #2
Do you have an FEL? If so, was it loaded? Either way, sounds like an underinflation issue. Don't forget, cooler weather can cause a significant drop in PSI and you aren't dealing with a lot of PSI to begin with. I doubt it is a cause for concern regardless of the type of tire you are using.
   / Front tire slipped off rim #3
I would suspect the tire pressure was not high enough, and that allowed it to happen. 40-50 psi should take care of it.
   / Front tire slipped off rim #4
Whoa there...that's twice the sidewall rating!!! Baby steps...try the recommended PSI first, and see what happens.
   / Front tire slipped off rim #5
And that recommended PSI is what for the sidewall rating for the tires the OP has on his tractor?
   / Front tire slipped off rim #7
Ok, I didn't expect them to be that light duty. My error. :)
I didn't find info on a GF2300
2018 KOMATSU D51PX-24 CRAWLER DOZER (A51246)
2018 KOMATSU...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2010 Chrysler Town and Country Touring Van (A50324)
2010 Chrysler Town...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
