Tires Front tire slipped off rim
   / Front tire slipped off rim #1
Axman
On a muddy hillside the other day the front tire on my GF2300 slid sideways and the tire went flat immediately. I took the tire off and aired it up and it seems just fine but is there any other things I might need to know in this weird happenstance? I've driven the tractor some since then and it seems fine.
   / Front tire slipped off rim #2
Do you have an FEL? If so, was it loaded? Either way, sounds like an underinflation issue. Don't forget, cooler weather can cause a significant drop in PSI and you aren't dealing with a lot of PSI to begin with. I doubt it is a cause for concern regardless of the type of tire you are using.
   / Front tire slipped off rim #3
I would suspect the tire pressure was not high enough, and that allowed it to happen. 40-50 psi should take care of it.
   / Front tire slipped off rim #4
Whoa there...that's twice the sidewall rating!!! Baby steps...try the recommended PSI first, and see what happens.
   / Front tire slipped off rim #5
And that recommended PSI is what for the sidewall rating for the tires the OP has on his tractor?
   / Front tire slipped off rim #7
Ok, I didn't expect them to be that light duty. My error. :)
I didn't find info on a GF2300
2016 Nissan Altima Sedan (A50324)
2016 Nissan Altima...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
2019 PRINOTH PANTHER T14R CRAWLER (A51242)
2019 PRINOTH...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
