Front tire removal questions
   / Front tire removal questions
That was my plan. I have some ironwood planks that'll do the trick well.
   / Front tire removal questions #12
Removing a tire and crawling under something aren’t even close to the same. You’re probably endangering yourself more to place the jack stand vs just pulling off the tire. I’d lift up the tractor with the loader and pull the lug nuts with my battery impact and then put a 6x6 under it and let it back down. I’ve done exactly that a few times. I’ve removed rear tires by lifting it with a backhoe stabilizer too. Now anything I’m crawling under gets proper support. Either wood blocks or beefy jack stands. I won’t use dinky jack stands or the drive on ramps.
   / Front tire removal questions #13
Tube to fix a car tire yes, tractor no. I have fixed and preventive a lot of slow leaks in equipment tires with slime leak sealant from tractor supply. $20/gallon. Hay rakes, bailer, trailers, manure spreader, hand carts, atvs and tractors. For the newest two tractor loader front tires used bulletproof sealant from Gemplers. No need to remove wheels to install. Do use loader to take the weight off the tires while installing the sealant. Gallon jugs have their own pump. Cheaper than tubes, better protection, less down time and still can plug a tubeless tire if needed. Nothing kills a day worse than having to fix or replace a tire.
   / Front tire removal questions #14
T for tight always worked for me, however I understand why the manufactures but the info into the service manual. LOL:laughing:
   / Front tire removal questions #15
^^^^what he said!
   / Front tire removal questions #17
We talk of torque wrenches, and I have about 3 and all calibrated as well.
Whenever I carefully torque to specs, Heads, rims etc) I always seem to get that feeling that I just stripped the threads.
Consequently I now simply leave them in my tool box.
   / Front tire removal questions #18
I have two nice torque wrenches.
Unless the torque is something critical (like an engine head) I use the that's enough method also.
   / Front tire removal questions #19
In aviation much had to be torqued to specs.
Like slip clutches on autopilot servos, shucks every nut had a torque spec of some sort.
Also all torque tools needed an annual re certification with correction charts, costly!
I recall being chastened because my master compass was not calibrated,*
I replied that a magnet will always point north and no, I did not cut out 10 deg from the compass rose.
*annual certification included 'swinging' the compass and calibrating corrections on all cardinal points.
(A procedure that I suspect was frequently faked.)
Since we did many new avionic installations 'swinging' was an important aspect of the job.
   / Front tire removal questions #20
Absolutely. I have had wheel issues in the field and lowered the bucket to the ground, lifted the front end with the loader and backed up to the barn using left and right brake. Changed many a flat tire this way.
Everything you do has an inherent degree of danger to it. Just think about what you are doing with the thought of what can go wrong with this plan. Jack stands in gravel or dirt, nope, 6x6's.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
10' CONTAINER (A52706)
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
CASE IH MX220 MAGNUM TRACTOR (A58375)
CASE IH MX220...
2014 Toro Groundsmaster 4500D Commercial Rotary Mower (A56857)
2014 Toro...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
