Front tire flats
/ Front tire flats #1
PondCreekFarm
SW Missouri
Kubota L3130
I seem to notice I get a lot of flat tires on my L3130 (R1 4x4). My father in law suggests that green slime product, but I have no experience with it. Is this adviseable or are there better alternatives?
/ Front tire flats #2
In my personal opinion, having the tires foam filled would be first choice, but that was too expensive for me, so slime is a good second choice.:D
/ Front tire flats #3
What is causing the flats? I live in an area covered with locust trees and I've only had one flat and that was from driving the tire off the rim because the load in the bucket was too heavy and I turned too sharply going down hill. But no punctures.
/ Front tire flats #4
Ive been told that if that stuff is used in a tire..and you need a repair patch vulcanized inside the tire...GOOD LUCK.. It wont "stick" worth a D***!!!
/ Front tire flats
I have a lot of small trees that have been cut off by the power company in an easement. I think, although I am uncertain, that these may be the culprit. I have also knocked the tire off turning too sharply, but only better driving can fix that. :)
/ Front tire flats #6
I've had my front tire go flat a half-dozen times in the past couple of months. I use it as a loading gauge for my FEL. If the front tires go flat, whatever I'm picking up is too heavy ;).
Jay
/ Front tire flats #8
I have had slime in the front tires of my L3010 for over a year, no more flats. I also use it in the tires of my two JD lawn tractors which all kept slow leaks. I first used it in my oldest JD (LX178) over four years ago and have yet to add air since. I am convinced it works. I did roll it down the side of a mountain once (thats all you really want to do of that). Tore the hood off but the tires still hold air and it runs great. I love Kubotas and Deeres...
/ Front tire flats #9
I have been plagued by "slow" leaking front tires on my BX24. It is difficult to detect because of the low profile and without any front end load shows a very small amount of deformation. With only 65 hrs and light duty yard work, I did not expect a flat on "both" front tires. The back ones are fine and have never added air. After removing the front tires and filling them with the specified 22 psi I laid them flat and poured a soapy-water solution around the bead, surface of the tread, and valve stem. Both tires experienced an amount of 1-2 bubbles every 10 seconds from the base of the valve stem. I did not see any bubbles anywhere else on the tire. It appears that these are bad valve stems, paint build-up, or something wedged between the hole in the rim and the valve stem. I squeezed a bit of liquid sealant around the stem-rim interface and stopped the leak on one tire, but the other one has re-appeared after about 2 weeks.
When time permits I should put in new valve stems, but that requires the removal of the tire from the rim. I'll push my dealer to repair them for free or under warranty with the seat recall and service next week.
/ Front tire flats #10
/ Front tire flats #11
The first time I picked up 2800 lbs with my FEL, the entire tractor genuflected and the front tires squished to about 1 inch high.... They looked OK without any load on FEL. I checked pressure, about 15 lbs... I read the printing on the side of the front tires about max inflation pressure... It's 60 PSI as i recall, anyway, I upped the PSI to the absolute max and am able to pick up the max load, make hard right/left turns in 4WD at very slow speed, even going down hill.... haven't rolled the tire off the rim yet.... am wondering what PSI those who have rolled their tires off the rim are using? Is it the max, or are you using squishy front tires?:)
/ Front tire flats #12
I run ~30PSI (max for my turfs), but I think that the pressure had probably bled down before I flattened the front the few times I've done it. It was always the left tire, and that one does have a tendency to lose pressure sometimes (but not always - which is weird).
Jay
/ Front tire flats #13
When I rolled off of mine the pressure was low. About 18 pounds in the one that didn't come off, maybe lower in the one that did. I knew that they looked a little "squishy" before it happened but just failed to do anything about it.
But here's the thing, the manual only calls for 22 psi, which seems low to me. I think I have 28 in them. I'd hesitate to go up to the max the tire will hold as this could affect the way the tractor handles under load and how forces are transmitted to the front driveline while under load. I'm no expert, just guessing.
/ Front tire flats #14
That should absoutely be a freebie repair - taking the wheels off should be easy too. 5 minute job when you use your FEL as a jack.
Personally, I'd tell the dealer that I no longer trusted the tubless stems, and I'd try to have him throw a couple of tubes in the tires for free. Then you know you won't have any problems.
Jay
/ Front tire flats #15
Might want to try one of Texas Refinery Corp.'s tire seal products. They make 2 of them, 1 being biodegradable. Tire Seal II P.G. and Tire Seal Also in Tire Seal in gallon bottle cases One nice thing is these products are also available in caulking tubes for easy installation.
They easily clean out if you should ever have to put a vulcanizing patch in and are chemically inert so they do not harm rims or tires.
/ Front tire flats #17
OK... low pressure, high load + sharp turn = tire rolls off rim.
Got it. That's what I figured and is why I went to the max PSI. I never know what I'm going to do... and when I pick up a HEAVY load I find that I ALSO am seeking to place it exactly so... within .5 inch of "perfect" and thus am likely to use max front end steering angle to do so.
I live in mesquite country and am very fortunate that I have not had flats. Slime in front tires may be helping.
/ Front tire flats #18
i put tubes in the front tires on my 4310 works great and is cheap
/ Front tire flats #19
As Bird suggested, foam is the final, one time, guaranteed fix.
I have foam filled tires on the front of both my tractors (B2910 and BX2200). I am a satisfied customer.
This is just a guess, but it would probably cost about $100 per tire to have the L3130 fronts foam filled, or a bit more.
Another advantage is the foam weighs a lot, and puts weight down low, an advantage on side slopes.
I was told, and assume that it may be true, that there are different densities of foam. My dealer referred me to a tire shop that put foam in with a little flex, rather than a very sold foam that might be more like concrete. I do have some bounce to my tires if I kick them or stand on them.
When a foam-filled tire wears out, it can be cut off the rim and the rim can be used again.
If you can afford it, foam fill the tires and forget about flats. That is what I did anyway...Yes, I occasionally do practice what I preach...:D:eek:
/ Front tire flats #20
I foam filled the front tires on my B2910 too. No more flats, and the extra balast is a nice bonus.
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
ASV RC85 Skidsteer (A66285)
ASV RC85 Skidsteer...
New/Unused 2 Post Car Lift (A65583)
New/Unused 2 Post...
2022 Ford Explorer AWD SUV (A61574)
2022 Ford Explorer...
2016 Ford Explorer (A59231)
2016 Ford Explorer...
CHROME HUB CAPS FOR SEMI TRUCK (A64276)
CHROME HUB CAPS...
