Front tire ballast?
   / Front tire ballast? #1
Portuguese Farmer
Central Portugal
Mitsubishi MTU26R
Tractor has the OEM three counter weights but it wants to "push" when turning sharp with the brush hog, maybe fill the tires would help?
   / Front tire ballast? #2
Front tires on most homeowner tractors are small. The added benefit of filled front tires will be negligible.
Raise the brush hog on sharp turns. Add weight to the bucket if you have FEL and bucket. Add suitcase weights to the front of the tractor. Go into FWD on turns. Slow down on turns.
Look at your overall mowing pattern. Perhaps it can be modified to reduce the number of tight turns.
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
Toro z turn (A56859)
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
