Front shaft removal?
/ Front shaft removal? #1
czechsonofagun
Elite Member
Old Dominion
Kubota B1750
I have a new boot for the front shaft, but I can not figure out where and how to disconnect the shaft. Looks like there are pins holding the universal joint on the shaft - is it the place to disconnect?
/ Front shaft removal? #2
You need a service manual for the job, really.
It would also help if you mention which Kubota you have.
/ Front shaft removal? #4
Agree about the service manuals. Very handy. Worth every penny. You can order them from Messicks.
/ Front shaft removal? #5
Not exactly sure on your particular model but, on my B2400 here is a sleeve that allows the driveshaft to be seperated from the Bi-speed unit. You'd still have to remove driveshaft from the pillow block bearing that is in front of the u-joint to access the boot.
/ Front shaft removal? #6
I don't know if this helps but heres a few pages from the B1550 parts manual.
  • Pages from B1550HSTD.pdf
On the end it was much easier than I anticipated. The whole fix including cleaning and lubing was not more than 20 minutes.
- Took out bolts for the lower U-joint cover and moved it up the shaft to get to the spring pin.
- Used the right size punch to drive out the spring pin holding the U-joint to the front axle pinion.
- The U-joint after the pin is out just slides off the splines; first from the front axle pinion, then from the shaft itself.
Assembly is the same in reverse order.
ENCLOSED OPERATOR CAB (A67714)
ENCLOSED OPERATOR...
WACKER NEUSON LTN6 LIGHT TOWER (A65056)
WACKER NEUSON LTN6...
2024 SANY 2Y26U EXCAVATOR (A65056)
2024 SANY 2Y26U...
PALLET OF MISC WHEELS (A67714)
PALLET OF MISC...
AREA WITH MISC PARTS/ITEMS (A67714)
AREA WITH MISC...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65057)
2001...
