Winches Front Mounted Winch on 2520
   / Front Mounted Winch on 2520 #1
goldenwings
New York
John Deere 2520
Just thought I'd share my experience mounting a Superwinch Terra 45 to the front of my 2520. Given the mounting location, this was the biggest physical size/dimension that would fit, also had the largest pulling capacity for this form factor. Also, as a plus since I only have the 20A alternator, this winch being a permanent magnet draws considerably less than the series wound counterparts. I searched amongst many forums and couldn't find anyone doing this on the 2520, so I thought I would share these photos to hopefully give someone else a hand, and let them know it is possible. I have already used the winch a couple of times to get myself out of some less than favorable situations, as well as a number of log pulls from the woods to the trails where they can be easily bucked and put into a wagon.
BTW this is my first post other than a review, so go easy on me.
   / Front Mounted Winch on 2520 #2
Welcome to TBN and you are doing great. Thanks for some neat pictures! They are always appreciated.
   / Front Mounted Winch on 2520 #3
:welcome:
That looks like a handy spot. What situations were you in that needed the winch?
I can think of a few as well, but have yet to consider the winch idea.
Appears you will need to remove the winch to put the FEL on, or isn't that a problem for you?
Actually I made sure it will clear the loader for normal operating. If you use the tractor as a deadman just put the bucket in the dirt and the winch cable goes right over the top. Or if you need to roll you can lift the bucket up a little and the line goes under. Obviously need to use common sense and pull relatively straight on with the bucket up a little.
As far as situations go.... mud while pulling my trailer loaded with firewood. I generally have to cross a couple of muddy sections to make it back to the house.
   / Front Mounted Winch on 2520 #5
Looks great.
:thumbsup:
   / Front Mounted Winch on 2520 #6
where did you pick up the winch from? i'm looking for one like it and wonder if you shopped around at all??
Install looks good that will be handy!
   / Front Mounted Winch on 2520 #7
Curious but what is the single line pull rating on the winch???
   / Front Mounted Winch on 2520 #8
Looks pretty good. I always like when people post there pick of the stuff they home make. I gives me ideas. Keep us updated with other add ons.
   / Front Mounted Winch on 2520 #9
I would opt for a Warn Winch if possible. The Superwinch I had a few years ago was super loud.
   / Front Mounted Winch on 2520 #10
Nice job. I've always wanted one. But, from reading on here, I kept getting pointed to a hydraulic winch instead of electric. I'd like a hydro one. Maybe one of these days I'll get off my butt and do it.
2019 John Deere 4044M (A53317)
2019 John Deere...
IVEY'S 7' AERATOR/PLUGGER (A57192)
IVEY'S 7'...
UNUSED FUTURE 13" MINI GRAPPLE (A57193)
UNUSED FUTURE 13"...
60" EXCAVATOR BUCKET (A52707)
60" EXCAVATOR...
PT 250 Gallon Fuel Tank (A56469)
PT 250 Gallon Fuel...
2015 Peterbilt 348 Jerr-Dan T/A Rollback Truck (A55852)
2015 Peterbilt 348...
