Winches Front Mounted Winch on 2520
   / Front Mounted Winch on 2520 #1
goldenwings
New York
John Deere 2520
Just thought I'd share my experience mounting a Superwinch Terra 45 to the front of my 2520. Given the mounting location, this was the biggest physical size/dimension that would fit, also had the largest pulling capacity for this form factor. Also, as a plus since I only have the 20A alternator, this winch being a permanent magnet draws considerably less than the series wound counterparts. I searched amongst many forums and couldn't find anyone doing this on the 2520, so I thought I would share these photos to hopefully give someone else a hand, and let them know it is possible. I have already used the winch a couple of times to get myself out of some less than favorable situations, as well as a number of log pulls from the woods to the trails where they can be easily bucked and put into a wagon.
BTW this is my first post other than a review, so go easy on me.
   / Front Mounted Winch on 2520 #2
Welcome to TBN and you are doing great. Thanks for some neat pictures! They are always appreciated.
   / Front Mounted Winch on 2520 #3
:welcome:
That looks like a handy spot. What situations were you in that needed the winch?
I can think of a few as well, but have yet to consider the winch idea.
Appears you will need to remove the winch to put the FEL on, or isn't that a problem for you?
Actually I made sure it will clear the loader for normal operating. If you use the tractor as a deadman just put the bucket in the dirt and the winch cable goes right over the top. Or if you need to roll you can lift the bucket up a little and the line goes under. Obviously need to use common sense and pull relatively straight on with the bucket up a little.
As far as situations go.... mud while pulling my trailer loaded with firewood. I generally have to cross a couple of muddy sections to make it back to the house.
   / Front Mounted Winch on 2520 #5
Looks great.
:thumbsup:
   / Front Mounted Winch on 2520 #6
where did you pick up the winch from? i'm looking for one like it and wonder if you shopped around at all??
Install looks good that will be handy!
   / Front Mounted Winch on 2520 #7
Curious but what is the single line pull rating on the winch???
   / Front Mounted Winch on 2520 #8
Looks pretty good. I always like when people post there pick of the stuff they home make. I gives me ideas. Keep us updated with other add ons.
   / Front Mounted Winch on 2520 #9
I would opt for a Warn Winch if possible. The Superwinch I had a few years ago was super loud.
   / Front Mounted Winch on 2520 #10
Nice job. I've always wanted one. But, from reading on here, I kept getting pointed to a hydraulic winch instead of electric. I'd like a hydro one. Maybe one of these days I'll get off my butt and do it.
2013 Ford Transit Connect Cargo Van (A55852)
2013 Ford Transit...
2025 KH72 72in Hydraulic 4-Way Clamshell Skid Steer Bucket (A55851)
2025 KH72 72in...
Standing Metal Firepit (A55853)
Standing Metal...
John Deere 5100M (A53317)
John Deere 5100M...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
UNUSED FUTURE P45 56" HYD BREAKER HAMMER (A57193)
UNUSED FUTURE P45...
