Backhoe Front mounted backhoe...of sorts
   / Front mounted backhoe...of sorts #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
Anyone have a FEL mounted backhoe? I have never seen one and I am interested in user/observer comments.
Are they useful or frustrating?
Thanks
   / Front mounted backhoe...of sorts #2
</font><font color="blue" class="small">( I have never seen one....)</font>
Neither have I nor have I even heard of such a thing.
   / Front mounted backhoe...of sorts #3
The only front mounted BHs I have seen are on bob-cats. I have also seen an extended arm with a hydraulic bucket that uses the FEL dump to angle the arm. Something like that would be fairly easy to make for a CUT. I see two problems one is visability, the other digging force with the curl cylinder.
   / Front mounted backhoe...of sorts #4
</font><font color="blue" class="small">( I see two problems one is visability, the other digging force with the curl cylinder. )</font>
I see a third problem. Dumping what you just dug up. A backhoe lets you swing to the side to dump the bucket. You would have to move the tractor after each dig.
   / Front mounted backhoe...of sorts #5
You don't like switching seats do you?
There are swinging hoes for skid steers that I believe mount on quick attach plate. Check the construction forum where the skid steer guys hang out.
</font><font color="blue" class="small">( You don't like switching seats do you? )</font>
Nah...it's a money thing. I would like a BH, but can't justify that much money at present. However, I might be able to talk myself into one of these if they prove to be practical. I realize that they have limitations. Just hoping to get thoughts from people that have use one.
The link below is one I "lifted" from another thread. Know of any other brands?
web page
   / Front mounted backhoe...of sorts #7
Search the Power Trac forum for references to the mini hoe. It is front mounted.
   / Front mounted backhoe...of sorts #8
<font color="blue"> The link below is one I "lifted" from another thread. Know of any other brands? </font>
Thats what I was talking about /forums/images/graemlins/grin.gif
   / Front mounted backhoe...of sorts #9
I was trying to remember where I'd posted that link, but you found it anyway/forums/images/graemlins/grin.gif. The Struck Dozer Page used /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif to have info on their versions and a movie but they don't seem to be there anymore. They had one fixed one, and another that swang to the side. There's pictures of the BH50 (fixed one) that I just found in the pdf brochure .
I'm not much of a fan of CADplans, but they have plans for a Skid Steer Hoe too.
I was thinking of making something like this, but in the end I designed and built a backhoe attachment.
Attached is a picture of a real simple backhoe that someone made (I guess) using pipe. It has a fixed bucket (no curl). I figure you could make something like this pretty easily that could attach to a bucket (or instead of a bucket).
I've seen another one too, but can't bring it to mind right now. Sorry. HTH. Andrew.
Howdy guys,
Just want to say thanks for the comments and ideas. I will proceed with more research, as time permits.
UNUSED FUTURE NWS38 NON CONNECTED WOOD SPLITTER (A57193)
UNUSED FUTURE...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
CONIBEAR EQ CO HYD SEED SPREADER (A57192)
CONIBEAR EQ CO HYD...
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
SET OF PALADIN JRB 60" PALLET FORKS (A52707)
SET OF PALADIN JRB...
