Backhoe Front mounted backhoe...of sorts
   / Front mounted backhoe...of sorts #1
Maine_Polack
Central Maine
Mahindra 6500 4WD
Anyone have a FEL mounted backhoe? I have never seen one and I am interested in user/observer comments.
Are they useful or frustrating?
Thanks
   / Front mounted backhoe...of sorts #2
</font><font color="blue" class="small">( I have never seen one....)</font>
Neither have I nor have I even heard of such a thing.
   / Front mounted backhoe...of sorts #3
The only front mounted BHs I have seen are on bob-cats. I have also seen an extended arm with a hydraulic bucket that uses the FEL dump to angle the arm. Something like that would be fairly easy to make for a CUT. I see two problems one is visability, the other digging force with the curl cylinder.
   / Front mounted backhoe...of sorts #4
</font><font color="blue" class="small">( I see two problems one is visability, the other digging force with the curl cylinder. )</font>
I see a third problem. Dumping what you just dug up. A backhoe lets you swing to the side to dump the bucket. You would have to move the tractor after each dig.
   / Front mounted backhoe...of sorts #5
You don't like switching seats do you?
There are swinging hoes for skid steers that I believe mount on quick attach plate. Check the construction forum where the skid steer guys hang out.
</font><font color="blue" class="small">( You don't like switching seats do you? )</font>
Nah...it's a money thing. I would like a BH, but can't justify that much money at present. However, I might be able to talk myself into one of these if they prove to be practical. I realize that they have limitations. Just hoping to get thoughts from people that have use one.
The link below is one I "lifted" from another thread. Know of any other brands?
web page
   / Front mounted backhoe...of sorts #7
Search the Power Trac forum for references to the mini hoe. It is front mounted.
   / Front mounted backhoe...of sorts #8
<font color="blue"> The link below is one I "lifted" from another thread. Know of any other brands? </font>
Thats what I was talking about /forums/images/graemlins/grin.gif
   / Front mounted backhoe...of sorts #9
I was trying to remember where I'd posted that link, but you found it anyway/forums/images/graemlins/grin.gif. The Struck Dozer Page used /forums/images/graemlins/confused.gif /forums/images/graemlins/mad.gif to have info on their versions and a movie but they don't seem to be there anymore. They had one fixed one, and another that swang to the side. There's pictures of the BH50 (fixed one) that I just found in the pdf brochure .
I'm not much of a fan of CADplans, but they have plans for a Skid Steer Hoe too.
I was thinking of making something like this, but in the end I designed and built a backhoe attachment.
Attached is a picture of a real simple backhoe that someone made (I guess) using pipe. It has a fixed bucket (no curl). I figure you could make something like this pretty easily that could attach to a bucket (or instead of a bucket).
I've seen another one too, but can't bring it to mind right now. Sorry. HTH. Andrew.
Howdy guys,
Just want to say thanks for the comments and ideas. I will proceed with more research, as time permits.
Brush cutter (A55973)
TURFMAST MHW2460 SWEEP-ALL PULL TYPE LAWN SWEEPER (A57192)
TURFMAST MHW2460...
2008 Ford F-450 Knapheide Service Truck (A55788)
2008 Ford F-450...
40' CONTAINER (A57192)
2500 GALLON POLY STORAGE TANK (A57192)
2500 GALLON POLY...
3650 (A47477)
3650 (A47477)
