Front Mount Stump Grinder
/ Front Mount Stump Grinder #1
hwp
Platinum Member
St. Catharines, Ontario, CANADA
Kubota F2400
Has anyone tried modifying a front mount stump grinder such as Textron (Steiner/Ransomes) or Hustler to their front mount tractor?
/ Front Mount Stump Grinder #2
Power Trac also makes a stump grinder. It is hydraulic. The small one for the 400 series requires 8GPM at 2500PSI. Someone on TBN put one on the backhoe of their Magna Trac. The trouble with a front mounted stump grinder that I would think might be a problem is that you could go forward and backwards, and up and down pretty easily, but side to side would require numerous repositions of the tractor. The articulation of the Power Trac units makes the side to side no problem, according to some of the users that have them.
Here's a link to a picture of it.
/ Front Mount Stump Grinder #3
Steiner and Ventrac articulated tractors also have front mounted stump grinders available. I have used mine extensively and am very pleased with the operation. See attached photo showing a Steiner stump grinder on my Ventrac. The thing out front is a large mirror so the operator can see the cutting operation clearly.
JackIL
Genie S40 Boom Lift (A64047)
Genie S40 Boom...
2015 Ford Taurus AWD Sedan (A64557)
2015 Ford Taurus...
Iranch High-End Tricycle (A64119)
Iranch High-End...
Soil-Max HD Cart (A64126)
Soil-Max HD Cart...
2021 Case TV450B (A64126)
2021 Case TV450B...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
