Sickle Bar Front mount sickle bar?
   / Front mount sickle bar? #1
dwyleecoyote
Northern Ohio
Ford 1320, Kubota 1140 CPX, Kubota BX2360
I am wondering if such a thing exists: front mounted sickle bar mower, operated by a mid mount PTO... Anyone ever see or hear of anything like this, for any tractor?
   / Front mount sickle bar? #2
The only ones I know of look similar to this although they won't fit a 4 wheel tractor. I'd sure like to have one though.
   / Front mount sickle bar? #3
You can get a hydraulic one and then modify it to fit the loader.
How would you plumb that? 3rd function? Or would that be called a front remote? I guess if I was making a frame anyway I could hook up right at the manifold where I just installed my backhoe connector.
Just thinking that it would make more sense to clear certain areas that way. Cut stuff down before you run over it. I seem to spend more time in reverse with my brush hog, just so I don't put a tractor tire on something I don't want to. I am just thinking, and it's probably more effort then its worth. Just bouncing the idea around.
   / Front mount sickle bar? #7
If you have a skid steer quick adapter on your FEL arms, I don't see why you couldn't rig up an attachment for a sicklebar and run the mower with a hydraulic motor. Sounds like a neat welding/hydraulics project.
Of course, self-propelled swathers (aka windrowers) have used front-mounted sicklebars for decades.
   / Front mount sickle bar? #8
Keep in mind a sickle bar is not a brush hog. They’re made to cut grass.
Anything is possible with enough money and know-how. But, I would guess that someone has tried it before, and there’s a reason you don’t see front mounted brush cutters for tractors. I don’t know what that reason is since you can get them on skid steers. Personally, I don't think a sickle bar on the front would be all that useful.
I don't have much experience with sickle bar mowers. My father had a walk behind, Troybilt I think, and I recall the advertising calling it a "field and brush" mower. I know it wouldn't take down small trees like my old brush hog will, but they did claim some pretty gnarly stuff could be cut with it.
   / Front mount sickle bar? #10
I THINK the Troybuilts were built a bit heavier than standard sickle bar mowers. I could be wrong about that.
2014 New Holland T8.360 MFWD Tractor (A51039)
2014 New Holland...
Vermeer SC802 (A50322)
IH 1566 Tractor (A50514)
IH 1566 Tractor...
WASTE OIL TANK (A50854)
WASTE OIL TANK...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A51039)
Hay Van FL-95 Bale...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A49461)
2015 Peterbilt 579...
