Front Mount Blower chain
/ Front Mount Blower chain #1
KubotaOne
Ontario, Canada
Kubota B-3030, FEL & BH
Hooked up my B2782 front mount snow blower to my B3030 for the first time this weekend. After about 200', the chain on the blower breaks. No rocks or sticks that I could see, only about 18" of light snow. I repair it (half hazardly mind you) and 100' later, boom, broken again.
Why are the sheer bolts not breaking first? My dealer is coming out this Friday to have a look, but I thought I'd see if anyone else has experienced this problem. By the way, I've yet to touch the factory sheer pins. We did have alot of snow (see pic) but still, the sheer bolts should have gone first.
/ Front Mount Blower chain #2
You didn't mention where the chain was breaking at. If it's at the master link, ensure that the open end of master link is on the trailing side of the chain travel direction. This may not be the problem but just food for thought.
It did break at the master link. Honestly, I didn't know master links were even directional, so I didn't pay attention to which direction it was installed. Learn something new everyday. I'll make sure to mention this to the dealer when he comes out, thanks for your reply.
</font><font color="blue" class="small">( You didn't mention where the chain was breaking at. If it's at the master link, ensure that the open end of master link is on the trailing side of the chain travel direction. This may not be the problem but just food for thought. )</font>
/ Front Mount Blower chain #4
I have the same tractor/blower, we don't have snow as of today, but i will let you know. PLEASE post the problem fix here! Scott.
/ Front Mount Blower chain #5
I had a Bota Blower on an L 3830 and the shear pin did not shear when I picked up a 2x4 in the auger. Bent it real bad and dealer would not warrenty it. Cost me over 100 bucks to get it somewhat straight. Got rid of it.
Scott, I will follow up next week (Tuesday) when I get home from my farm. I've done some searches regarding similar blowers to ours. One poster claimed the shear bolts installed from the factory were incorrect, and he too broke the chain. His solution was to go down a grade. However, I find it hard to believe Kubota (or who ever manufactures them) would make such a serious mistake by installing a shear bolt that is "too" strong. Most of the posts I read were the opposite, they had to go up a grade to stop them from breaking.
</font><font color="blue" class="small">( I have the same tractor/blower, we don't have snow as of today, but i will let you know. PLEASE post the problem fix here! Scott. )</font>
/ Front Mount Blower chain #7
Regarding the installation of proper shear bolts: don't assume the manufacturer got it right. It could very well be that the bolts used were regular bolts not shear bolts.
Make sure the augers and fan will spin freely (well greased too) when the shear bolts are removed. If things are rusted together, then the shear bolt function will be nullified.
thanks Peter, we'll check the shear bolts Friday, just in case they are wrong. I already bought spares. The fan and augers spin freely, and I greased all the fittings.
</font><font color="blue" class="small">( Regarding the installation of proper shear bolts: don't assume the manufacturer got it right. It could very well be that the bolts used were regular bolts not shear bolts.
Make sure the augers and fan will spin freely (well greased too) when the shear bolts are removed. If things are rusted together, then the shear bolt function will be nullified. )</font>
/ Front Mount Blower chain #9
My question is Why did anything break? If you were only in snow (no lumber, rocks, sticks or animals) then nothing should have given way. Is there a bad tooth on any sprockets that could be stressing the chain?
/ Front Mount Blower chain #10
A qick explanation for my previous advice: If the open end of master link is facing the direction of travel, any small bump(ie.. chain tensioner or other debri ) can dislodge the clip and cause it to disengage from the pin thus causing chain to separate. /forums/images/graemlins/mad.gif By reversing the clip, any bump only forces the clip onto the pin and shouldn't remove it. An old motorcycle trick from years ago!!
</font><font color="blue" class="small">( A qick explanation for my previous advice: If the open end of master link is facing the direction of travel, any small bump(ie.. chain tensioner or other debri ) can dislodge the clip and cause it to disengage from the pin thus causing chain to separate. /forums/images/graemlins/mad.gif By reversing the clip, any bump only forces the clip onto the pin and shouldn't remove it. An old motorcycle trick from years ago!! )</font>
Like I said, you learn something new everyday. Thanks for your reply, I'll be sure to mention this to my dealer tomorrow.
/ Front Mount Blower chain #12
Thank you kubotaone, i will be looking for that post you can be sure!
</font><font color="blue" class="small">( Thank you kubotaone, i will be looking for that post you can be sure! )</font>
My dealer came out on Friday, as promised. He checked to see that the sprockets were aligned correctly, and they were. Next he replaced the master link (B-2400 - he did install the master link clip in the correct direction, thanks again for the tip). Next he adjusted the chain tension. The bolt used to tighten the chain is virtually useless, he used a hammer to move the "adjustable" side of the sprocket assembly. He'd get the corrrect amount of chain slack (1/4" sag) but when he tightened the four bolts to lock it in place, the chain would tighten up severely. After fiddling with it for about a half hour, he got the proper slack with the four bolts secured.
I had about 6" to 8" of snow to try it after he left. Cleared my 750' gravel driveway, plus trails to my sheds and our parking area - all without a hitch. Chain held and no shear bolt breakage.
Conclusion? His guess was the chain was too tight. Everything else appeared to be ok. For those of you who own a similar blower, I would recommend checking the chain tension, I can see how it would be easy to have it too tight.
/ Front Mount Blower chain #14
Thank you kubotaone, for the explanation.
It will help the rest of us at TBN. /forums/images/graemlins/grin.gif
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
2018 BOBCAT E50 EXCAVATOR (A64279)
2018 BOBCAT E50...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A59912)
2019 CRUISE CAR...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
20in Single Cylinder Grapple Bucket Skid Steer Attachment (A61572)
20in Single...
